umat.pdf
2025-09-20
下载
大小:427.91KB
Abaqus umat的官方文档
下载于http://130.149.89.49:2080/v2016/index.html
You need define only the deviatoric stress and Jacobian
to define a fully incompressible material response through user subroutine UMAT.
For incompressible pressure-sensitive materials the element choice is particularly important when using user
subroutine UMAT.
节选段落二:
is called, so that only the corotational part
of the stress integration should be done in UMAT.
节选段落三:
Subroutine UMAT merely acts as a directory here. The argument
list may be the same as that used in subroutine UMAT.
Example: Simple linear viscoelastic material
As a simple example of the coding of user subroutine UMAT, consider the linear, viscoelastic model shown in
Figure 1.1.44–1.
