kisssys入门实例教程3.pdf
2018-01-28 下载:71
下载
大小:1.81MB
官方网站教材
(Section 7.4).
2.2 Systematic procedure
The following steps are involved when building a KISSsys model:
1. Planning: Naming, range and goals of the model
2. Insert mechanical component in the tree structure (red Icons)
3. Connect mechanical component to each other (grey Icons)
4.节选段落二:
Before a model can be opened in KISSsys, a directory
must be defined in which the KISSsys model is to be stored. Therefore a new appropriate directory name has to
be created in the main directory KISSsys before starting to model.节选段落三:
In our case:
C:\Programme\KISSsoft 03-2008\KISSsys\tutorial-003.
(Section 7.4).
4.节选段落二:
In our case:
