fluent一些参考资料
浏览:175004 评论:20 收藏:1
Fluent_UDF 中文教程
http://cn.ziddu.com/download/256984/Fluent_UDF.rar.html
Fluent UDF 高级应用技术培训-实例
http://cn.ziddu.com/download/256973/FluentUDF2.rar.html
边界条件设置
http://cn.ziddu.com/download/256974/bc.rar.html
动网格
http://cn.ziddu.com/download/256977/Dynamic_Mesh.rar.html
多孔介质
http://cn.ziddu.com/download/256985/porous.rar.html
多项流
http://cn.ziddu.com/download/256983/VOF.rar.html
燃烧
http://cn.ziddu.com/download/256976/combustion.rar.html
噪声
http://cn.ziddu.com/download/256981/noise.rar.html
Fluent后处理
http://cn.ziddu.com/download/256975/aftertreatment.rar.html
Gambit
http://cn.ziddu.com/download/256982/Gambit.rar.html
最新的fluent噪声培训资料(上)
http://cn.ziddu.com/download/263248/fluent_noise_1.rar.html
最新的fluent噪声培训资料(中)
http://cn.ziddu.com/download/263250/fluent_noise_2.rar.html
最新的fluent噪声培训资料(下)
http://cn.ziddu.com/download/263252/fluent_noise_3.rar.html
给初学者-一个关于vof模型建立的帮助过程
http://cn.ziddu.com/download/263254/vof_1131780516.zip.html
http://cn.ziddu.com/download/263255/tut16_1131780666.pdf.html
Fluent IcePak 教程
http://cn.ziddu.com/download/263257/IcePak.pdf.html
流体力学基础
http://cn.ziddu.com/download/263258/Fluid_basic.rar.html
湍流模型
http://cn.ziddu.com/download/263259/turbulentmodel.pdf.html
fluent 中文帮助
http://cn.ziddu.com/download/263482/fluentPDF7.pdf.html
CFD实用经验指南
http://cn.ziddu.com/download/264745/20084120531137628.rar.html
ANSYS ICEM-CFD中文入门教材
http://cn.ziddu.com/download/266002/1.rar.html
波浪模拟
http://cn.ziddu.com/download/266427/wavecfdsimulation.rar.html
Hypermesh6.0中文基础培训
http://cn.ziddu.com/download/270638/Hypermesh.rar.html
EXCEED中文使用手册
http://cn.ziddu.com/download/270639/EXCEED.zip.html
Fluent 6.3 User's Guide
网格
http://cn.ziddu.com/download/272219/mesh.rar.html
文档
http://cn.ziddu.com/download/272221/Fluent_Htm_Doc_install-ntx86-6.3.part01.rar.html
http://cn.ziddu.com/download/272233/Fluent_Htm_Doc_install-ntx86-6.3.part02.rar.html
http://cn.ziddu.com/download/272240/Fluent_Htm_Doc_install-ntx86-6.3.part03.rar.html
http://cn.ziddu.com/download/272706/Fluent_Htm_Doc_install-ntx86-6.3.part04.rar.html
http://cn.ziddu.com/download/272709/Fluent_Htm_Doc_install-ntx86-6.3.part05.rar.html
http://cn.ziddu.com/download/272711/Fluent_Htm_Doc_install-ntx86-6.3.part06.rar.html
http://cn.ziddu.com/download/272714/Fluent_Htm_Doc_install-ntx86-6.3.part07.rar.html
http://cn.ziddu.com/download/272715/Fluent_Htm_Doc_install-ntx86-6.3.part08.rar.html
http://cn.ziddu.com/download/273568/Fluent_Htm_Doc_install-ntx86-6.3.part09.rar.html
http://cn.ziddu.com/download/273570/Fluent_Htm_Doc_install-ntx86-6.3.part10.rar.html
http://cn.ziddu.com/download/273571/Fluent_Htm_Doc_install-ntx86-6.3.part11.rar.html
http://cn.ziddu.com/download/273572/Fluent_Htm_Doc_install-ntx86-6.3.part12.rar.html
1.Introduction to Using FLUENT: Fluid Flow and Heat Transfer in a Mixing Elbow
http://cn.ziddu.com/download/274304/elbow.rar.html
2.Modeling Periodic Flow and Heat Transfer
http://cn.ziddu.com/download/274305/tubebank.rar.html
3.Modeling External Compressible Flow
http://cn.ziddu.com/download/274484/airfoil.rar.html
4.Modeling Unsteady Compressible Flow
http://cn.ziddu.com/download/274307/nozzle.rar.html
5.Modeling Radiation and Natural Convection
http://cn.ziddu.com/download/274308/rad.rar.html
6.Using a Non-Conformal Mesh
http://cn.ziddu.com/download/274309/filmcool.rar.html
7.Modeling Flow Through Porous Media
http://cn.ziddu.com/download/274310/catalytic_converter.rar.html
8.Using a Single Rotating Reference Frame
http://cn.ziddu.com/download/274311/disk.rar.html
9.Using Multiple Rotating Reference Frames
http://cn.ziddu.com/download/274315/blower.rar.html
10.Using the Mixing Plane Model
http://cn.ziddu.com/download/274316/fanstage.rar.html
11.Using Sliding Meshes
http://cn.ziddu.com/download/275812/axial-comp.rar.html
12.Using Dynamic Meshes
http://cn.ziddu.com/download/275841/valve.rar.html
13.Modeling Species Transport and Gaseous Combustion
http://cn.ziddu.com/download/275848/gascomb.rar.html
14.Using the Non-Premixed Combustion Model
http://cn.ziddu.com/download/275850/berl.rar.html
15.Modeling Surface Chemistry
http://cn.ziddu.com/download/275852/surface.rar.html
16.Modeling Evaporating Liquid Spray
http://cn.ziddu.com/download/275853/sector.rar.html
17.Using the VOF Model
http://cn.ziddu.com/download/275871/inkjet.rar.html
18.Modeling Cavitation
http://cn.ziddu.com/download/275854/cav.rar.html
19.Using the Mixture and Eulerian Multiphase Models
http://cn.ziddu.com/download/275855/tee.rar.html
20.Using the Eulerian Multiphase Model for Granular Flow
http://cn.ziddu.com/download/275857/mixtank.rar.html
21.Modeling Solidification
http://cn.ziddu.com/download/276269/solid.rar.html
22.Using the Eulerian Granular Multiphase Model with Heat Transfer
http://cn.ziddu.com/download/276270/fluid-bed.rar.html
23.Postprocessing
http://cn.ziddu.com/download/276272/chip.cas.gz.html
http://cn.ziddu.com/download/276274/chip.dat.gz.html
24.Turbo Postprocessing
25.Parallel Processing
http://cn.ziddu.com/download/276281/parallel_process.zip.html
Gambit 2.1 User's Guide
http://cn.ziddu.com/download/287906/Gambit2.1Documentation.part1.rar.html
http://cn.ziddu.com/download/287907/Gambit2.1Documentation.part2.rar.html
http://cn.ziddu.com/download/287911/Gambit2.1Documentation.part3.rar.html
http://cn.ziddu.com/download/287913/Gambit2.1Documentation.part4.rar.html
http://cn.ziddu.com/download/287914/Gambit2.1Documentation.part5.rar.html
http://cn.ziddu.com/download/287915/Gambit2.1Documentation.part6.rar.html
GAMBIT用户手册
http://cn.ziddu.com/download/289592/GAMBIT_1.rar.html
GAMBIT培训资料
http://cn.ziddu.com/download/289593/GAMBIT.rar.html
计算流体动力学分析- CFD软件原理与应用
http://cn.ziddu.com/download/293443/1.rar.html
FLUENT:流体工程仿真计算机实例与应用_韩占忠等
http://cn.ziddu.com/download/293452/1.rar.html
FLUENT技术基础与应用实例
http://cn.ziddu.com/download/293453/1.rar.html
水沸腾算例
http://cn.ziddu.com/download/319956/water.rar.html
明渠流动
http://cn.ziddu.com/download/334111/flow.rar.html
边界条件设置
动网格
多孔介质
多项流
燃烧
噪声
Fluent后处理
Gambit
最新的fluent噪声培训资料(上)
最新的fluent噪声培训资料(中)
最新的fluent噪声培训资料(下)
Fluent IcePak 教程
流体力学基础
湍流模型
fluent 中文帮助
CFD实用经验指南
波浪模拟
Hypermesh6.0中文基础培训
EXCEED中文使用手册
网格
文档
23.Postprocessing
GAMBIT用户手册
GAMBIT培训资料
FLUENT技术基础与应用实例
水沸腾算例
明渠流动
