Bladegen之叶片泵叶片建模
首先在Workbench中选择Bladegen模块
勾选创建轮毂和创建所有叶片选项
选择径向叶轮标签,并输入Z值和R值(横轴为Z向,纵向为R)。
选择厚度/角度模式
输入叶片包角140度,厚度值及叶片个数为7
进入设计总窗口
The most critical operation in the meridional view is to define the shape
of the hub and shroud curve. The endpoints for these curves were
specified when Initial Design Parameters were entered in the Initial
Meridional configuration dialog.
The hub and shroud profile for this case are well defined automatically.
In this case, there is no need for any additional modificati**.
意思是轮毂和挡风罩(套罩)形状的定义在子午面上很关键,我们在
前面初始化子午面结构参数已定义了这些曲线的终点。
它们的其它轮廓由系统自动生成,不需要修改。用户可以通过改变坐标值及曲线特性进行修改。
双击各点修改坐标值来定义进口和出口截面
1. Double click the shroud inlet point at the top left of the meridional view.
2. The Point Location Dialog will open. The Horizontal value is the Axial location (Z co-ordinate) and the Vertical value represents the Radius.
3. Enter -10 and 110 for the horizontal and vertical values. Click OK.
4. Double click the hub inlet point (bottom left corner) and enter -10 and 25 for the horizontal and vertical values. Click OK.
5. Double click the hub outlet point (top right corner) and enter 91 and 250 for the horizontal and vertical values. Click OK.
6. Double click the shroud outlet point (top left corner) and enter 63 and 250 for the horizontal and vertical values. Click OK.
