求助,hypermesh求解出现错误
NOTE # 9199
MSGLMT=STRICT is active, all messages will be printed.
You can suppress some less important warning messages by use of
MSGLMT=BRIEF or UNREF (in config file or in the input data).
*** See next message about line 565684 from file:
C:/Users/Administrator/Desktop/hypermesh/Hypermesh/ture.fem
"CQUAD4 353047 0 367824 367825 367826 367827"
This line was interpreted as:
565684:CQUAD4, 353047, 0, 367824, 367825, 367826, 367827
*** ERROR # 1000 *** in the input data:
Incorrect data in field # 3. Field 'PID' of CQUAD4 bulk data.
Expected INT > 0 or blank, found INTEGER (0).
*** See next message about line 565685 from file:
"CQUAD4 353048 0 367824 367827 367826 367825"
565685:CQUAD4, 353048, 0, 367824, 367827, 367826, 367825
*** See next message about line 565686 from file:
"CQUAD4 353049 0 367828 367829 367830 367831"
565686:CQUAD4, 353049, 0, 367828, 367829, 367830, 367831
*** See next message about line 565687 from file:
"CQUAD4 353050 0 367828 367831 367830 367829"
565687:CQUAD4, 353050, 0, 367828, 367831, 367830, 367829
*** See next message about line 565688 from file:
"CQUAD4 353051 0 367832 367833 367834 367835"
565688:CQUAD4, 353051, 0, 367832, 367833, 367834, 367835
*** See next message about line 565689 from file:
"CQUAD4 353052 0 367832 367835 367834 367833"
565689:CQUAD4, 353052, 0, 367832, 367835, 367834, 367833
*** See next message about line 565690 from file:
"CQUAD4 353053 0 367836 367837 367838 367839"
565690:CQUAD4, 353053, 0, 367836, 367837, 367838, 367839
*** See next message about line 565691 from file:
"CQUAD4 353054 0 367836 367839 367838 367837"
565691:CQUAD4, 353054, 0, 367836, 367839, 367838, 367837
*** See next message about line 565692 from file:
"CQUAD4 353055 0 367840 367841 367842 367843"
565692:CQUAD4, 353055, 0, 367840, 367841, 367842, 367843
*** See next message about line 565693 from file:
"CQUAD4 353056 0 367840 367843 367842 367841"
565693:CQUAD4, 353056, 0, 367840, 367843, 367842, 367841
*** More of ERROR messages # 1000 were suppressed...
MAXIMUM DISK SPACE USED 1 MB
COMPUTE TIME INFORMATION
EXECUTION STARTED Tue Sep 14 20:15:26 2021
EXECUTION COMPLETED Tue Sep 14 20:15:29 2021
ELAPSED TIME 00:00:02
CPU TIME 00:00:02
*** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
***** END OF REPORT *****
For Useful OptiStruct Tips and Tricks, go to the URL:
http://www.altairhyperworks.com/tips.aspx
Following warning messages appeared too many times
and were suppressed:
1000
Total of 2488 repeat error message(s) were suppressed.
To see more messages use "MSGLMT" control card in the data or config file.
There were 2498 error messages during input processing.
The first message is repeated below:
