一个考虑腐蚀的相场损伤模型源代码
 原始文献:《A phase field formulation for dissolution-driven stress corrosion cracking》
一个考虑腐蚀的相场损伤模型源代码的图1
来源于该文章,对腐蚀相关损伤建模的可以详细阅读原文,理解整个程序,作者模拟效果如下:
一个考虑腐蚀的相场损伤模型源代码的图2
一个考虑腐蚀的相场损伤模型源代码的图3
一个考虑腐蚀的相场损伤模型源代码的图4
原始代码如下:
   module kvisual
   implicit none
   real*8 UserVar(4,24,70000)
   integer nelem
   save
   end module
   subroutine uexternaldb(lop,lrestart,time,dtime,kstep,kinc)
   include 'aba_param.inc'
   !implicit real(a-h o-z)
   dimension time(2)
   if (lop.eq.0) then !start of analysis
    call mutexinit(1)
   endif
   return
   end
   subroutine uel(rhs,amatrx,svars,energy,ndofel,nrhs,nsvars,
   1 props,nprops,coords,mcrd,nnode,u,du,v,a,jtype,time,dtime,
   2 kstep,kinc,jelem,params,ndload,jdltyp,adlmag,predef,npredf,
   3 lflags,mlvarx,ddlmag,mdload,pnewdt,jprops,njpro,period)
   use kvisual
   dimension rhs(mlvarx,*),amatrx(ndofel,ndofel),props(*),svars(*),
   1 energy(*),coords(mcrd,nnode),u(ndofel),du(mlvarx,*),v(ndofel),
   2 a(ndofel),time(2),params(*),jdltyp(mdload,*),adlmag(mdload,*),
   3 ddlmag(mdload,*),predef(2,npredf,nnode),lflags(*),jprops(*)
   parameter(ndim=2,ntens=4,ninpt=4,nsvint=24,ndof=4)
   dimension wght(ninpt),dN(nnode,1),dNdz(ndim,nnode),stress(ntens),
   1 dNdx(ndim,nnode),b(ntens,nnode*ndim),ddsdde(ntens,ntens),
   2 stran(ntens),xm(nnode,nnode),BB(nnode,nnode),dstran(ntens),
   3 statevLocal(nsvint),eelas(ntens)
!  initialising
   do k1=1,ndofel
    rhs(k1,1)=0.d0
   end do
   amatrx=0.d0
   wght=1.d0
!  find number of elements
   if (dtime.eq.0.d0) then
    if (jelem.eq.1) then
    nelem=jelem
    else
    CALL MutexLock(1)
    if (jelem.gt.nelem) nelem=jelem
    CALL MutexUnlock(1)
    endif
   endif
!  reading parameters
   D=props(5)
   xL0=props(6)
   a_phi=props(7)
   wh=props(8)
   AA=props(9)
   xk=props(10)
   ef=props(11)
   t0=props(12)
   cse=1.d0    ! Normalized equilibrium concentration of solid
   cle=0.036d0  ! Normalized equilibrium concentration of liquid
   xkap=1.d-7   ! well-conditioning parameter
   T=300.d0    ! Temperature (K)
   R=8314.d0   ! Gas constant
   do kintk=1,ninpt
!  evaluate shape functions and derivatives
    call kshapefcn(kintk,ninpt,nnode,ndim,dN,dNdz)
    call kjacobian(jelem,ndim,nnode,coords,dNdz,djac,dNdx,mcrd)
    call kbmatrix(dNdx,ntens,nnode,ndim,b)
    dvol=wght(kintk)*djac
!  compmute phase field, concentration and strains from nodal values
    phi=0.d0
    dphi=0.d0
    cL=0.d0
    do inod=1,nnode
    phi=phi+dN(inod,1)*u(ndim*nnode+inod)
    dphi=dphi+dN(inod,1)*du(ndim*nnode+inod,1)
    cL=cL+dN(inod,1)*u((ndim+1)*nnode+inod)
    end do
    dstran=matmul(b,du(1:ndim*nnode,1))
!  defining suitable functions
    hphi=-2.d0*phi**3+3.d0*phi**2
    dhphi=-6.d0*phi**2+6.d0*phi
    ddhphi=-12.d0*phi+6.d0
    gphi=(1.d0-phi)*(1.d0-phi)*phi**2
    dgphi=2.d0*phi+4.d0*phi**3-6.d0*phi**2
    ddgphi=2.d0+12.d0*phi**2-12.d0*phi
!  recover and assign state variables
    call kstatevar(kintk,nsvint,svars,statevLocal,1)
    stress=statevLocal(1:ntens)
    stran(1:ntens)=statevLocal((ntens+1):(2*ntens))
    eelas(1:ntens)=statevLocal((2*ntens+1):3*ntens)
    ti=statevLocal(4*ntens+7)
    ei=statevLocal(4*ntens+8)
!  call umat to obtain stresses and constitutive matrix
    call kumat(props,ddsdde,stress,dstran,ntens,statevLocal,eelas,
   1 spd,hphi,phi,xkap,Sh0,eqplas,deqpl)
!  enhance the value of L
    Sh=(hphi+xkap)*Sh0
    pls=statevLocal(4*ntens+1)
    xkm=dexp(Sh*7.12d3/(R*T))*(1.d0+pls/(props(3)/props(1)))
    if (time(2).lt.3.01d0) then
    ti=0.d0
    ei=0.d0
    else
    ei=ei+statevLocal(4*ntens+5)
    ti=ti+dtime
    endif
    if (ei.gt.ef) then
    ti=0.d0
    ei=0.d0
    endif
    if (ti.lt.t0) then
    xL=xL0*xkm
    else
    xL=xL0*xkm*dexp(-xk*(ti-t0))
    endif
!  store state variables
    statevLocal(1:ntens)=stress(1:ntens)
    statevLocal((ntens+1):(2*ntens))=statevLocal((ntens+1):(2*ntens))
   1 +dstran(1:ntens)
    statevLocal(4*ntens+2)=phi
    statevLocal(4*ntens+3)=xL
    statevLocal(4*ntens+4)=Sh
    statevLocal(4*ntens+6)=cL
    statevLocal(4*ntens+7)=ti
    statevLocal(4*ntens+8)=ei
    call kstatevar(kintk,nsvint,svars,statevLocal,0)
!  form and assemble stiffness matrix and internal force vector
    amatrx(1:16,1:16)=amatrx(1:16,1:16)+dvol*
   2 ((hphi+xkap)*matmul(matmul(transpose(b),ddsdde),b))
    rhs(1:16,1)=rhs(1:16,1)-
   1 dvol*(matmul(transpose(b),stress)*(hphi+xkap))
    fc=AA*((cL-hphi*(cse-cle)-cle)**2)+wh*gphi
    dfc=-2.d0*AA*(cL-hphi*(cse-cle)-cle)*(cse-cle)*dhphi+wh*dgphi
    ddfc=wh*ddgphi-2.d0*AA*(cse-cle)*
   1 (ddhphi*(cL-hphi*(cse-cle)-cle)-dhphi*dhphi*(cse-cle))
    BB=matmul(transpose(dNdx),dNdx)
    xm=matmul(dN,transpose(dN))
    amatrx(17:24,17:24)=amatrx(17:24,17:24)+
   1 +dvol*(xm/dtime+xL*xm*ddfc+xL*a_phi*BB)
    rhs(17:24,1)=rhs(17:24,1)-dvol*
   1 (matmul(xm,du(17:24,1))/dtime+xL*dN(:,1)*dfc
   2 +xL*a_phi*matmul(transpose(dNdx),matmul(dNdx,u(17:24))))
    ww=(cse-cle)*dhphi
    amatrx(25:32,25:32)=amatrx(25:32,25:32)+dvol*(xm/dtime+D*BB)
    rhs(25:32,1)=rhs(25:32,1)-dvol*(
   1 matmul(xm,du(25:32,1))/dtime+D*(matmul(transpose(dNdx),
   2 matmul(dNdx,u(25:32)))
   3 -ww*matmul(transpose(dNdx),matmul(dNdx,u(17:24)))))
! output
    UserVar(kintk,1:ntens,jelem)=stress(1:ntens)*(hphi+xkap)
    UserVar(kintk,(ntens+1):(4*ntens+8),jelem)=
   1 statevLocal((ntens+1):(4*ntens+8))
   end do   ! end loop on material integration points
   RETURN
   END
   subroutine kshapefcn(kintk,ninpt,nnode,ndim,dN,dNdz)
c
c
   parameter (gaussCoord=0.577350269d0)
   dimension dN(nnode,1),dNdz(ndim,*),coord24(2,4)
   data coord24 /-1.d0, -1.d0,
   2        1.d0, -1.d0,
   3       -1.d0, 1.d0,
   4        1.d0, 1.d0/
!  determine (g,h)
   g=coord24(1,kintk)*gaussCoord
   h=coord24(2,kintk)*gaussCoord
!  shape functions
   dN(1,1)=-0.25d0*(1.d0-g)*(1.d0-h)*(1.d0+g+h)
   dN(2,1)=0.25d0*(1.d0+g)*(1.d0-h)*(g-h-1.d0)
   dN(3,1)=0.25d0*(1.d0+g)*(1.d0+h)*(g+h-1.d0)
   dN(4,1)=0.25d0*(1.d0-g)*(1.d0+h)*(h-g-1.d0)
   dN(5,1)=0.5d0*(1.d0-g*g)*(1.d0-h)
   dN(6,1)=0.5d0*(1.d0+g)*(1.d0-h*h)
   dN(7,1)=0.5d0*(1.d0-g*g)*(1.d0+h)
   dN(8,1)=0.5d0*(1.d0-g)*(1.d0-h*h)
!  derivative d(Ni)/d(g)
   dNdz(1,1)=0.25d0*(1.d0-h)*(2.d0*g+h)
   dNdz(1,2)=0.25d0*(1.d0-h)*(2.d0*g-h)
   dNdz(1,3)=0.25d0*(1.d0+h)*(2.d0*g+h)
   dNdz(1,4)=0.25d0*(1.d0+h)*(2.d0*g-h)
   dNdz(1,5)=-g*(1.d0-h)
   dNdz(1,6)=0.5d0*(1.d0-h*h)
   dNdz(1,7)=-g*(1.d0+h)
   dNdz(1,8)=-0.5d0*(1.d0-h*h)
!  derivative d(Ni)/d(h)
   dNdz(2,1)=0.25d0*(1.d0-g)*(g+2.d0*h)
   dNdz(2,2)=0.25d0*(1.d0+g)*(2.d0*h-g)
   dNdz(2,3)=0.25d0*(1.d0+g)*(2.d0*h+g)
   dNdz(2,4)=0.25d0*(1.d0-g)*(2.d0*h-g)
   dNdz(2,5)=-0.5d0*(1.d0-g*g)
   dNdz(2,6)=-(1.d0+g)*h
   dNdz(2,7)=0.5d0*(1.d0-g*g)
   dNdz(2,8)=-(1.d0-g)*h
   return
   end
   subroutine kjacobian(jelem,ndim,nnode,coords,dNdz,djac,dNdx,mcrd)
!  Notation: djac - Jac determinant; xjaci - inverse of Jac matrix
!  dNdx - shape functions derivatives w.r.t. global coordinates
   dimension xjac(ndim,ndim),xjaci(ndim,ndim),coords(mcrd,nnode),
   1 dNdz(ndim,nnode),dNdx(ndim,nnode)
   xjac=0.d0
   do inod=1,nnode
    do idim=1,ndim
    do jdim=1,ndim
     xjac(jdim,idim)=xjac(jdim,idim)+
   1    dNdz(jdim,inod)*coords(idim,inod)
    end do
    end do
   end do
    djac=xjac(1,1)*xjac(2,2)-xjac(1,2)*xjac(2,1)
    if (djac.gt.0.d0) then ! jacobian is positive - o.k.
    xjaci(1,1)=xjac(2,2)/djac
    xjaci(2,2)=xjac(1,1)/djac
    xjaci(1,2)=-xjac(1,2)/djac
    xjaci(2,1)=-xjac(2,1)/djac
    else ! negative or zero jacobian
    write(7,*)'WARNING: element',jelem,'has neg. Jacobian'
    endif
   dNdx=matmul(xjaci,dNdz)
   return
   end
   subroutine kbmatrix(dNdx,ntens,nnode,ndim,b)
!  Notation, strain tensor: e11, e22, e33, e12, e13, e23
   dimension dNdx(ndim,nnode),b(ntens,nnode*ndim)
   b=0.d0
   do inod=1,nnode
    b(1,ndim*inod-ndim+1)=dNdx(1,inod)
    b(2,ndim*inod-ndim+2)=dNdx(2,inod)
    b(4,ndim*inod-ndim+1)=dNdx(2,inod)
    b(4,ndim*inod-ndim+2)=dNdx(1,inod)
   end do
   return
   end
c*****************************************************************
   subroutine kstatevar(npt,nsvint,statev,statev_ip,icopy)
c
c  Transfer data to/from element-level state variable array from/to
c  material-point level state variable array.
c
   dimension statev(*),statev_ip(*)
   isvinc=(npt-1)*nsvint  ! integration point increment
   if (icopy.eq.1) then ! Prepare arrays for entry into umat
    do i=1,nsvint
    statev_ip(i)=statev(i+isvinc)
    enddo
   else ! Update element state variables upon return from umat
    do i=1,nsvint
    statev(i+isvinc)=statev_ip(i)
    enddo
   end if
   return
   end
   subroutine kumat(props,ddsdde,stress,dstran,ntens,statev,eelas,
   1 spd,hphi,phi,xkap,Sh,eqplas,deqpl)
c
c  Subroutine with the material model
c
   include 'aba_param.inc' !implicit real(a-h o-z)
   dimension props(*),ddsdde(ntens,ntens),stress(ntens),statev(*),
   + dstran(ntens),eelas(ntens),eplas(ntens),flow(ntens),olds(ntens),
   + oldpl(ntens)
   parameter(toler=1.d-6,newton=20)
   eelas(1:ntens)=statev((2*ntens+1):3*ntens)
   eplas(1:ntens)=statev((3*ntens+1):4*ntens)
   eqplas=statev(1+4*ntens)
   deqpl=statev(5+4*ntens)
   olds=stress
   oldpl=eplas
!  Initialization
   ddsdde=0.d0
   E=props(1) ! Young's modulus
   xnu=props(2) ! Poisson's ratio
   Sy=props(3) ! Yield stress
   xn=props(4) ! Strain hardening exponent
!  Build elastic stiffness matrix
   eg=E/(1.d0+xnu)/2.d0
   elam=(E/(1.d0-2.d0*xnu)-2.d0*eg)/3.d0
   do i=1,3
    do j=1,3
    ddsdde(j,i)=elam
    end do
    ddsdde(i,i)=2.d0*eg+elam
   end do
   do i=4,ntens
    ddsdde(i,i)=eg
   end do
!  Calculate predictor stress and elastic strain
   stress=stress+matmul(ddsdde,dstran)
   eelas=eelas+dstran
!  Calculate equivalent von Mises stress
   Smises=(stress(1)-stress(2))**2+(stress(2)-stress(3))**2
   1 +(stress(3)-stress(1))**2
   do i=4,ntens
    Smises=Smises+6.d0*stress(i)**2
   end do
   Smises=sqrt(Smises/2.d0)
!  Get yield stress from the specified Ehardening curve
   Sf=Sy*(1.d0+E*eqplas/Sy)**xn
!  Determine if active yielding
   if (Smises.gt.(1.d0+toler)*Sf) then
!  Calculate the flow direction
    Sh=(stress(1)+stress(2)+stress(3))/3.d0
    flow(1:3)=(stress(1:3)-Sh)/Smises
    flow(4:ntens)=stress(4:ntens)/Smises
!  Solve for Smises and deqpl using Newton's method
    deqpl=0.d0
    Et=E*xn*(1.d0+E*eqplas/Sy)**(xn-1)
    do kewton=1,newton
    rhs=Smises-(3.d0*eg)*deqpl-Sf
    deqpl=deqpl+rhs/((3.d0*eg)+Et)
!    if(deqpl.lt.0.d0) deqpl=-deqpl
    Sf=Sy*(1.d0+E*(eqplas+deqpl)/Sy)**xn
    Et=E*xn*(1.d0+E*(eqplas+deqpl)/Sy)**(xn-1)
    if(abs(rhs).lt.toler*Sy) exit
    end do
    if (kewton.eq.newton) write(7,*)'WARNING: plasticity loop failed'
! update stresses and strains
    stress(1:3)=flow(1:3)*Sf+Sh
    eplas(1:3)=eplas(1:3)+3.d0/2.d0*flow(1:3)*deqpl
    eelas(1:3)=eelas(1:3)-3.d0/2.d0*flow(1:3)*deqpl
    stress(4:ntens)=flow(4:ntens)*Sf
    eplas(4:ntens)=eplas(4:ntens)+3.d0*flow(4:ntens)*deqpl
    eelas(4:ntens)=eelas(4:ntens)-3.d0*flow(4:ntens)*deqpl
    eqplas=eqplas+deqpl
!  Calculate the plastic strain energy density
    do i=1,ntens
    spd=spd+(stress(i)+olds(i))*(eplas(i)-oldpl(i))/2.d0
    end do
!  Formulate the jacobian (material tangent)
    effg=eg*Sf/Smises
    efflam=(E/(1.d0-2.d0*xnu)-2.d0*effg)/3.d0
    effhrd=3.d0*eg*Et/(3.d0*eg+Et)-3.d0*effg
    do i=1,3
    do j=1,3
     ddsdde(j,i)=efflam
    enddo
    ddsdde(i,i)=2.d0*effg+efflam
    end do
    do i=4,ntens
    ddsdde(i,i)=effg
    end do
    do i=1,ntens
    do j=1,ntens
     ddsdde(j,i)=ddsdde(j,i)+effhrd*flow(j)*flow(i)
    end do
    end do
   endif
!  Store strains in state variable array
   statev((2*ntens+1):3*ntens)=eelas
   statev((3*ntens+1):4*ntens)=eplas
   statev(4*ntens+1)=eqplas
   statev(4*ntens+5)=deqpl
   return
   end
   subroutine umat(stress,statev,ddsdde,sse,spd,scd,rpl,ddsddt,
   1 drplde,drpldt,stran,dstran,time,dtime,temp2,dtemp,predef,dpred,
   2 cmname,ndi,nshr,ntens,nstatv,props,nprops,coords,drot,pnewdt,
   3 celent,dfgrd0,dfgrd1,noel,npt,layer,kspt,jstep,kinc)
   use kvisual
   character*8 cmname
   dimension stress(ntens),statev(nstatv),ddsdde(ntens,ntens),
   1 ddsddt(ntens),drplde(ntens),stran(ntens),dstran(ntens),
   2 time(2),predef(1),dpred(1),props(nprops),coords(3),drot(3,3),
   3 dfgrd0(3,3),dfgrd1(3,3),jstep(4)
   ddsdde=0.0d0
   noffset=noel-nelem
   statev(1:nstatv)=UserVar(npt,1:nstatv,noffset)
   return
   end
材料属性和状态变量如下:
一个考虑腐蚀的相场损伤模型源代码的图5
一个考虑腐蚀的相场损伤模型源代码的图6
该代码非常容易和晶体塑性结合使用,模拟多晶的腐蚀行为,感兴趣的可以阅读原文直接获取,也可以直接加入知识星球下载交流讨论:
一个考虑腐蚀的相场损伤模型源代码的图7
