SimSolid用户案例——大型设备
Using SimSolid I was able to quickly model this in a very realistic manner with sliding connections, a clamping force on the piston and a matching reaction on the cylinder body. I’m really pleased with the results, and they are inline with our expectations.
Total time from start to finish including all setup/preparation and fixing some errors in the CAD model – 1.5 hours.
We wouldn’t even consider analysing with the below method in a traditional mesh based system – it would take too long to get any useful information out. We would have ended up splitting the assembly into multiple parts, and running separate simulations for each - this would easily consume a day, and likely be less accurate.
Tony Jones
Andron Handling
SimSolid让我能够以非常逼真的方式建立滑动连接、活塞上的夹紧力以及缸体上的匹配。 结果让我非常满意,并且符合我们的期望。
在SimSolid中,从开始到结束包括所有设置/准备和修复CAD模型中的一些错误,总共消耗了1.5小时。
我们甚至不会考虑在传统的基于网格的系统中使用以下方法进行分析 - 获取任何有用信息需要很长时间。 我们应该会将装配体分成多个部分,并为每个部分运行单独的模拟 - 这至少消耗一天,而且可能不太准确。
Tony Jones
Andron Handling
【想获得更多信息,请加技术邻微信客服 jishulink888。也可以申请试用、免费测算、报名培训、研发人员20人以上的企业可以申请免费上门内训
