Moldflow CAD Doctor
最近MF公司刚推出一个新模块-CAD Doctor,对修复、简化CAD模型很有效。
Moldflow CAD Doctor™
Moldflow CAD Doctor™ is a powerful tool for checking, correcting, healing, and simplifying solid models imported from popular 3D CAD systems in preparation for analysis using Moldflow Plastics Advisers® (MPA®) or Moldflow Plastics Insight® (MPI®).
Moldflow CAD Doctor Version 1.0 supports the import of IGES and CATIA V4 (requires optional add-on license) formats. Moldflow CAD Doctor 1.0 outputs models in Moldflow’s proprietary UDM format which can then be imported into MPI 5.0 Revision 1 or higher and MPA 7.1.
Capabilities
• Import and manipulate IGES and CATIA V4 models
• Perform diagnostics check to assess over 30 different types of model quality problems
• Choose which types of model checks are to be performed as well as adjust the tolerance or thresholds used in these checking operations
• Intelligent default tolerance and threshold values suitable for MPA and MPI supplied with the software
• Quickly locate quality issues with intelligent, colored error assignment on model surfaces
• Automatically stitch free edges in the model
• Preview the effectiveness of the free edge stitching process and if necessary adjust the tolerance value
• Perform crucial geometry healing step to insure the integrity of the model
• Optimize the model for use with MPA or MPI by simplifying features that add complexity to the geometry
• Simplification tools can be used with small fillets, radii, slivers, chamfers, lettering, tool symbols, embossing, and logos
• Geometry creation and editing tools give the user the flexibility of not having to revert to a CAD system to make simple geometry modifications
• Create points, curves, faces and surfaces through numerous geometry creation tools
• Export quality solid models for use with MPA and MPI simulations
• Measure distances, curvature, included angles and coordinates of various entities directly on the model
Geometry Import Options
• IGES
• CATIA V4 **
** Requires optional add-on license
Supported Platforms
Intel Pentium/Xeon-based Microsoft Windows 2000 and XP
AMD Athlon-based Microsoft Windows 2000 and XP最近MF公司刚推出一个新模块-CAD Doctor,对修复、简化CAD模型很有效。
Capabilities
• IGES
• CATIA V4 **
Supported Platforms
