求助关接触的问题
浏览:142313 回答:2
求助关接触的问题
我在做一个有关接触的问题,但是求解的时候有错误,请帮帮我,不胜感激。
*** WARNING *** CP = 0.688 TIME= 23:03:32
Use of the -M switch is no longer recommended for normal ANSYS use.
ANSYS now dynamically allocates memory as needed. Only use the -M
switch if you are certain that you need to do so.
*** ERROR *** CP = 11.266 TIME= 23:31:41
Real constant 2 has been referenced by at least element types 1 and 2,
one of which is contact element type.
*** ERROR *** CP = 11.344 TIME= 23:34:38
The model data was checked and there were errors found.
Please check output or errors file ( C:\Documents and
Settings\jefferson\file.err ) for messages.
我不知道怎么办,希望高手能够帮帮我,万分感谢!!!
我是新手,不好意思,要怎么修改一下?求教高手了~~~!
2008年5月28日
maudlin
one of which is contact element type. 感觉说的挺清楚的了
2008年5月26日
