关于受脉冲的瞬态响应
浏览:118472 回答:6
弱弱的问一个问题: 一个一端固定,另一端自由的悬臂梁,在给一个脉冲(力)信号后想查看梁的瞬态响应(振动的位移-时间图)。如果没有阻尼的话,板的位移应该是正弦的响应吧,可是我却不知道怎么样用瞬态分析正确察看位移,apdl老是写的不对,出来的图像是一个合成的信号。而且如果修改时间步长deltim的话,响应也会随之有很大变化,不知道是为什么。望有哪位有经验的朋友帮忙看一下,这里先谢谢了:
finish
/clear
l_platte=500e-3 !悬臂梁长度[m]
b_platte=60e-3 !悬臂梁宽度[m]
t_platte=2e-3 !悬臂梁厚度[m]
ele_l_platte=10e-3 !网格划分大小[m]
Kraft=-20 !激励信号[N]
/prep7
!Element-Typ
et,1,shell63
r,1,t_platte
! Steel-Material
mp,ex,1,210e9 ! [N/m^2]
mp,prxy,1,0.3
mp,dens,1,7860 ! [kg/m^3]
rectng,0,l_platte,0,b_platte
esize,ele_l_platte
asel,all
amesh,all
!transient analysis
/solu
antype,trans
trnopt,full
outres,all,all
TINTP,0.0
deltim,0.5
kbc,1
nsel,r,loc,x,0
d,all,all
alls
time,10
solve
time,15
f,node(l_platte,b_platte/2,0),fz,Kraft
solve
time,25
fdele,node(l_platte,b_platte/2,0),all
solve
time,50
solve
finish
/post26
numvar,200
nsol,2,node(l_platte,b_platte/2,0),u,z,disp !2 ist die Referenz-Nummer
/axlab,y,strain
plvar,2
finish
/clear
Kraft=-20 !激励信号[N]
/prep7
!Element-Typ
et,1,shell63
r,1,t_platte
! Steel-Material
mp,prxy,1,0.3
esize,ele_l_platte
asel,all
amesh,all
!transient analysis
/solu
antype,trans
trnopt,full
outres,all,all
TINTP,0.0
deltim,0.5
kbc,1
nsel,r,loc,x,0
d,all,all
alls
time,10
solve
time,15
solve
time,25
solve
time,50
solve
finish
/post26
numvar,200
/axlab,y,strain
plvar,2
