求完整的Abaqus[1].v6.7安裝步驟 !
浏览:81695 回答:2
本人现在急需学习Abaqusv6.7,可是怎么安都俺不上,求各位大侠帮忙发一个完整的Abaqus[1].v6.7安装步骤!
liaoyanguo
1. edit SHooTERS\license.dat (from CD1)
change <pc-name> to your pc-name , also change 27003 to 27000
save license.dat to a temporary folder eg: c:\new folder
2. set System Environment Variables (in Control Panel-->System-->Advanced-->Environment Variables)
Variable name : LM_license_FILE
variable value: 27000@your pc-name
3. Install Abaqus license server, select "just install licensing utilities"
3.1 copy and paste license.dat from the temporary folder to c:\ABAQUS\license\
3.2 use lmtools.exe to config the license-server
Service/license File-->Tick the Configuration using Services option
Config Services tab -->Service Name-->type in any name eg: abaqus
Path to the lmgrd.exe file--> C:\ABAQUS\license\lmgrd.exe
Path to the license file----> C:\ABAQUS\license\license.dat
Path to the debug log file--> C:\ABAQUS\license\license.log
tick Use Service option
tick Satrt Server at Power Up
Clic Save service button --> clic Yes
3.3 Start/Stop/Reread
clic Start Server button to start up the license-server
3.4 Server Diags
clic Perform Diagnostics to see if the license-server is up and running O.K.
4. Install Abaqus Products --> input 27000@your pc-name when asked for a license server.
5. copy exec\* to <installdir>\exec
6. Enjoy.
2008年9月30日
bme
具体的步骤一时说不清,建议看自带的安装说明。不过有一点可以肯定的是安装完license manager以后需要启动服务才能进行后续的安装,否则安装不能继续
2008年9月24日
