大家帮我看看这个模型出了什么错?
浏览:116365 回答:3
For a self contact surface, the facets of the elements in element set WarnElemFacetThickPt63d-Step1 are thicker than 0.6 times an edge or diagonal length of the facets. Use the MAXRATIO parameter on *SURFACE DEFINITION to allow automatic rescaling of the contact thicknesses where necessary for this surface. Refer to the status file for further details.
这是个其中的警告
Excessive rotation of nodes in node set ErrNodeExcessRotation-Step1.
Excessive rotation increment at one node
ABAQUS/Explicit Analysis exited with an error - Please see the status file for possible error messages if the file exists.
这是error
我是模拟板材被冲破。警告信息我要怎么弄才可以消除?。我模型错在哪?我要把冲头位移小点就运行好好的。位移大点就不行了
这是个其中的警告
这是error
