请教各位高手,帮我看看这个DF文件。多谢!
浏览:148662
多谢各位朋友,message 是 下面这个:
*** Error in convert external to internal Adaptive constraint 1 node 133116
*** Error can't find a right relation for CONSTRAINED_ADAPTIVITY 1
Nodes 0 0 155704
*** Error input data failed with: 1 errors
E r r o r t e r m i n a t i o n
Memory required for explicit solution : 0
Additional dynamically allocated memory: 0
Total: 0
T i m i n g i n f o r m a t i o n
CPU(seconds) %CPU Clock(seconds) %Clock
Initialization ....... 0.0000E+00 0.00 0.0000E+00 0.00
Element processing ... 0.0000E+00 0.00 0.0000E+00 0.00
Binary databases ..... 0.0000E+00 0.00 0.0000E+00 0.00
ASCII database ....... 0.0000E+00 0.00 0.0000E+00 0.00
Contact algorithm .... 0.0000E+00 0.00 0.0000E+00 0.00
Contact entities ..... 0.0000E+00 0.00 0.0000E+00 0.00
Rigid bodies ......... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Nonlinear ... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Lin. Alg. ... 0.0000E+00 0.00 0.0000E+00 0.00
T o t a l s 0.0000E+00 0.00 0.0000E+00 0.00
Problem time = 0.0000E+00
Problem cycle = 0
Total CPU time = 0 seconds ( 0 hours 0 minutes 0 seconds)
CPU time per zone cycle = 0 nanoseconds
Clock time per zone cycle= 0 nanoseconds
Number of CPU's 0
NLQ used/max 96/ 96
Start time 10/28/2008 09:34:26
End time 10/28/2008 09:34:30
Elapsed time 4 seconds ( 0 hours 0 minutes 4 seconds)
Nodes 0 0 155704
Total: 0
Problem cycle = 0
Number of CPU's 0
NLQ used/max 96/ 96
