求高手指点:圆筒件径向加载问题?
浏览:112161 回答:2
message文件提示:
*** Error line number 4017 contains improperly formatted data
(This is line# 3294 of file
F:\model and software\ug\excercises\blank\2\新建文件夹\新建文件夹\model1.mod)
--------------------------------------------------------------line# 4017 -------
*LOAD_NODE_POINT
*** Error reading *LOAD_NODE card.
*** Error in keyword command:
616 1 8 0.05
Check near line # 4018
(This is line# 3295 of file
*** Warning The following lines will be skipped:
1. 617 1 8 0.10
2. 618 1 8 0.16
3. 619 1 8 0.21
4. 620 1 8 0.26
5. 621 1 8 0.31
6. 622 1 8 0.36
7. 623 1 8 0.41
8. 624 1 8 0.45
9. 625 1 8 0.50
10. 626 1 8 0.54
11. 627 1 8 0.59
12. 628 1 8 0.63
13. 629 1 8 0.67
14. 630 1 8 0.71
15. 631 1 8 0.74
16. 632 1 8 0.78
17. 633 1 8 0.81
18. 634 1 8 0.84
19. 635 1 8 0.87
20. 636 1 8 0.89
21. 637 1 8 0.91
22. 638 1 8 0.93
23. 639 1 8 0.95
24. 640 1 8 0.97
25. 641 1 8 0.98
26. 642 1 8 0.99
27. 643 1 8 0.99
28. 644 1 8 1.00
29. 645 1 8 1.00
30. 646 1 8 1.00
*** Error line number 4050 contains improperly formatted data
(This is line# 3327 of file
--------------------------------------------------------------line# 4050 -------
*LOAD_NODE_POINT
615 2 8 1.00
Check near line # 4051
(This is line# 3328 of file
1. 616 2 8 1.00
2. 617 2 8 1.00
3. 618 2 8 0.99
4. 619 2 8 0.99
5. 620 2 8 0.98
6. 621 2 8 0.97
7. 622 2 8 0.95
8. 623 2 8 0.93
9. 624 2 8 0.91
10. 625 2 8 0.89
11. 626 2 8 0.87
12. 627 2 8 0.84
13. 628 2 8 0.81
14. 629 2 8 0.78
15. 630 2 8 0.74
16. 631 2 8 0.71
17. 632 2 8 0.67
18. 633 2 8 0.63
19. 634 2 8 0.59
20. 635 2 8 0.54
21. 636 2 8 0.50
22. 637 2 8 0.45
23. 638 2 8 0.41
24. 639 2 8 0.36
25. 640 2 8 0.31
26. 641 2 8 0.26
27. 642 2 8 0.21
28. 643 2 8 0.16
29. 644 2 8 0.10
30. 645 2 8 0.05
31. 646 2 8 0.00
32.
expanding memory to 343781
*** Error input data failed with: 4 errors
E r r o r t e r m i n a t i o n
mod文件添加的加载节点
*LOAD_NODE_POINT
$ NODE DOF LCID SF
615 1 8 0.000
616 1 8 0.053
617 1 8 0.104
618 1 8 0.155
619 1 8 0.210
620 1 8 0.259
621 1 8 0.310
622 1 8 0.358
623 1 8 0.407
624 1 8 0.454
625 1 8 0.500
626 1 8 0.544
627 1 8 0.588
628 1 8 0.629
629 1 8 0.670
630 1 8 0.707
631 1 8 0.743
632 1 8 0.777
633 1 8 0.810
634 1 8 0.838
635 1 8 0.866
636 1 8 0.890
637 1 8 0.913
638 1 8 0.933
639 1 8 0.950
640 1 8 0.966
641 1 8 0.978
642 1 8 0.987
643 1 8 0.994
644 1 8 0.998
645 1 8 1.000
646 1 8 1.000
*LOAD_NODE_POINT
$ NODE DOF LCID SF
615 2 8 1.000
616 2 8 1.000
617 2 8 0.998
618 2 8 0.994
619 2 8 0.987
620 2 8 0.978
621 2 8 0.966
622 2 8 0.950
623 2 8 0.933
624 2 8 0.913
625 2 8 0.890
626 2 8 0.866
627 2 8 0.838
628 2 8 0.810
629 2 8 0.777
630 2 8 0.743
631 2 8 0.707
632 2 8 0.670
633 2 8 0.629
634 2 8 0.588
635 2 8 0.544
636 2 8 0.500
637 2 8 0.454
638 2 8 0.407
639 2 8 0.358
640 2 8 0.310
641 2 8 0.259
642 2 8 0.210
643 2 8 0.155
644 2 8 0.104
645 2 8 0.053
646 2 8 0.000
molove
可以改一下
load curve 變成兩條~~在試試看~~
或者~load curve 重新輸入
2008年11月19日
先佩服你一下吧。将节点力用sf因子做成非均布载荷了。估计是手动改的吧?
建议你把k文件发上来看看原因。这样不好说的。
2008年11月11日
