运行superforge时出现错误
浏览:170756 回答:1
DATE :15-11-08 TIME :19:02:51
%I-P2149003-P2XXTXIX_PACKET_OPTION_UNITS,,,
SI-unit system is defined: m,kg,sec,k
%I-P2148701-P2XXTXIX_PACKET_OPTION_HEATXFR,,,
Heat transfer activated by PARAM,HEATXFR.
%I-P2122628-P2XXTXIX_PACKET_HOT_YIELD,,,
Fraction of mechanical work that will be converted to heat is
set equal to 0.90000
%I-P2130313-P2XXTXIX_PACKET_EDTMSRF,,,
The variables on the workpiece are taken from the
finite-volume elements center.
%W-P2143305-P2XXTXIX_PACKET_MESH,,,
Default starting number is set to GRID
Default starting number is set to ELEMENT
%I-P2022803-P2XXTXIX_SET_GLOBAL_DEFAULT,,,
No minimum time step defined , so 10% of initial time step will be used
%I-P2156706-P2_2D_TO_3D_OUTPUT_DEFAULTS,,,
SLIVER output will be created.
Since the A1- and
or the A2-option for 3D model output are not set
defaults have been determined as follows:
A1 is -y distance : 0.000000E+00
A2 is +y distance : 0.500819E-05
Since the A1- and
%W-P2108906-P2_DEFINE_VARIABLES_FOR_EDIT,,,
Variable CONTACT is not legal in input set FV_WORKPIECE and is
therefore ignored.
This may result in an empty edit set.
Variable EFFPL-IN is not legal in input set FV_WORKPIECE and is
therefore ignored.
Variable EFFPL-MID is not legal in input set FV_WORKPIECE and is
therefore ignored.
Variable EFFPL-OUT is not legal in input set FV_WORKPIECE and is
therefore ignored.
Variable EFFST-IN is not legal in input set FV_WORKPIECE and is
therefore ignored.
NO MORE MESSAGES OF THIS KIND WILL BE WRITTEN
%W-P2150608-P2_CHECK_NEWMATSURF_VARS,,,
Variable TXY is requested by edit set MSURFOUT: WORKPIECE
This is not a variable of the finite volume mesh.
The variable will therefore be skipped.
Variable TYZ is requested by edit set MSURFOUT: WORKPIECE
Variable DIEFILL is requested by edit set MSURFOUT: WORKPIECE
Variable LUBE is requested by edit set MSURFOUT: WORKPIECE
Since the A1- and
%I-P2156705-P2_2D_TO_3D_OUTPUT_DEFAULTS,,,
3D finite-volume model output has the following settings:
-y distance for the finite-volume layer: -0.500819E-02
+y distance for the finite-volume layer: 0.500819E-02
%I-P3158501-V3_CHECK_VOLUME_CROD_POL_2D,,,
2D surface SURFACE3 contains CRODs with have the normals pointing
inward. The connectivity will be automatically reversed to obtain a
positive volume.
%I-P3158503-V3_CHECK_VOLUME_CROD_POL_2D,,,
Volume of 2D surface SURFACE3 is 0.21000E-02
2D surface SURFACE1 contains CRODs with have the normals pointing
positive volume.
Volume of 2D surface SURFACE1 is 0.18789E-02
Volume of 2D surface SURFACE2 is 0.58504E-02
%I-P3162602-P3_BRUTE_FORGE_INIT_PEN_2D,,,
MATSURF grid point ( 0) has initial penetration. The
grid point is moved to
x = 0.11619E-01, z = 0.79801E-01
over a distance 0.33920E-08
x = 0.10522E-01, z = 0.79801E-01
x = 0.85492E-02, z = 0.79801E-01
x = 0.71725E-02, z = 0.79801E-01
x = 0.57958E-02, z = 0.79801E-01
%I-P3170605-P3SF_COMPUTE_TAYLOR_VELOCITY,,,(13),
UHEL VELOCITY = 0.621430E+02
TAYLOR VELOCITY = 0.144637E+03
THIS MESSAGE IS FOR INFORMATIONAL PURPOSES ONLY
%I-P5175701-P5_EDIT_DIESURFACE_2D,,,
In cycle zero the die vars are not available yet. Output is restricted
to connectivity.
to connectivity.
%I-P5179501-V5_PUT_ARC_MATSURF_NODE_DATA_3D,,,
In cycle zero the contact flag is not available as output variable for
the MATSURF
%E-GP140302-P3XXTXIX_CYCLE_ZERO,,,
You are not authorized to use MSC.SuperForge 2D
Please, see also earlier messages on authorization.
PROCESS
SuperForge 2004 Single-CPU Windows
SUMMARY OF MESSAGES (INCLUDING NON-PRINTED MESSAGES)
INFORMATIVE : 25
WARNINGS : 11
ERRORS : 1
请高手帮忙看一下。
xulinagood
请问楼主是怎么解决的,就上面出现的错误,我摆弄了两天还没出来,很急,忘告诉一下,不胜感激,谢谢!
2010年10月11日
