求助!!
浏览:175575 回答:1
在用NATRAN 计算后 调入patran显示结果是报错
Direct Results Access file is already attached. To re-attach with different Translation Parameters, please detach the file using the Analysis form option Delete "Attachment" then re-attach. File: "J:\模型\1111.xdb"
这个什么意思,怎么解决??
了解的说下撒
谢谢了!
这个什么意思,怎么解决??
了解的说下撒
谢谢了!
