为什么中途退出?
浏览:123124 回答:11
___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version : ls971d R3.2 Date: 08/06/2008 |
| Revision: 46862 Time: 08:15:14 |
| Features enabled in this version: |
| 32 Bit IEEE Binary File |
| Licensed to: |
| Platform : PC WIN32(PCWIN) |
| OS Level : WINDOWS XP00/NT/XP (SSE) |
| Compiler : Intel Fortran Compiler 9.1 |
| Hostname : hp-sgh504026k |
| Precision : Double precision (I8R8) |
| Product ID : 46920 |
| Unauthorized use infringes LSTC copyrights |
Input file: E:/ch041/530113~1/2/dwb-g.dyn
The native file format : 64-bit small endian
Memory size from command line: 524288000
JOBID : dwb-g
Memory option : AUTO selected
expanding memory to 524288000 starting ls-dyna
*** Error LS-DYNA failed to allocate 524288000 words of memory.
Please use the memory option on the execute line.
T i m i n g i n f o r m a t i o n
CPU(seconds) %CPU Clock(seconds) %Clock
Initialization ....... 0.0000E+00 0.00 0.0000E+00 0.00
Element processing ... 0.0000E+00 0.00 0.0000E+00 0.00
Binary databases ..... 0.0000E+00 0.00 0.0000E+00 0.00
ASCII database ....... 0.0000E+00 0.00 0.0000E+00 0.00
Contact algorithm .... 0.0000E+00 0.00 0.0000E+00 0.00
Contact entities ..... 0.0000E+00 0.00 0.0000E+00 0.00
Rigid bodies ......... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Nonlinear ... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Lin. Alg. ... 0.0000E+00 0.00 0.0000E+00 0.00
T o t a l s 0.0000E+00 0.00 0.0000E+00 0.00
Problem time = 0.0000E+00
Problem cycle = 0
Total CPU time = 0 seconds ( 0 hours 0 minutes 0 seconds)
CPU time per zone cycle = 0 nanoseconds
Clock time per zone cycle= 0 nanoseconds
Number of CPU's 0
NLQ used/max 96/ 96
Start time 06/13/2009 10:48:54
End time 06/13/2009 10:48:54
Elapsed time 0 seconds( 0 hours 0 min. 0 sec.) for 0 cycles
E r r o r t e r m i n a t i o n
| www.lstc.com |
| Licensed to: |
JOBID : dwb-g
Problem cycle = 0
Number of CPU's 0
NLQ used/max 96/ 96
