下面这些错误怎么解决??
浏览:67475
1.Previous testing revealed that 909 of the 175700 selected elements
violate shape warning limits. To review warning messages, please see
the output or error file, or issue the CHECK command.
2.ANSYS, Inc.-supplied version of USTRESS has been used. This works with
the COMMENTED EXAMPLE input attached with ustress.F.
3.Element 45473 does not have the result data stored for all layers.
Set KEYOPT(8)=1 before solution to view layer results.
