芜湖小铁匠——DYNA问题解答贴
浏览:124722 回答:19
LSDYNA版最近比较冷清
特开此贴,回答有关关键字方面的问题,共同学习。
有任何问题请跟帖,必回复!
(19)
      Date: 05/29/2020      Time: 00:13:06      ___________________________________________________
     |  Livermore  Software  Technology  Corporation   |
     |  7374 Las Positas Road                          |
     |  Livermore, CA 94551                            |
     |  Tel: (925) 449-2500  Fax: (925) 449-2507       |
     |  www.lstc.com                                   |
     |_________________________________________________|
     |  LS-DYNA, A Program for Nonlinear Dynamic       |
     |  Analysis of Structures in Three Dimensions     |
     |  Version : ls971s R3.2.1   Date: 09/18/2008     |
     |  Revision: 47756           Time: 14:57:19       |
     |  Features enabled in this version:              |
     |    Shared Memory Parallel                       |
     |    ANSYS Database format                        |
     |    ANSYS License (ans110)                       |
     |  Licensed to:                                   |
     |  Platform   : PC WINX64                         |
     |  OS Level   :  (Build 9200)V 2003 X64           |
     |  Compiler   : Intel Fortran Compiler 10.1       |
     |  Hostname   : DESKTOP-CMQP08L                   |
     |  Precision  : Single precision (I4R4)           |
     |  Product ID : 47821                             |
     |  Unauthorized use infringes LSTC copyrights     |
     |_________________________________________________| Input file: 0-4-30-1-V610.k
 The native file format       : 32-bit small endian
 Memory size from *KEYWORD    :   800000000
 expanding   memory to   800000000 starting ls-dyna********  notice  ********  notice  ********  notice  ********
* This is the LS-DYNA Finite Element code.                   *
* Neither LSTC nor the authors assume any responsibility for *
* the validity, accuracy, or applicability of any results    *
* obtained from this system. The user must verify his own    *
* results.                                                   *
* LSTC endeavors to make the LS-DYNA code as complete,       *
* accurate and easy to use as possible.                      *
* Suggestions and comments are welcomed.  Please report any  *
* errors encountered in either the documentation or results  *
* immediately to LSTC through your site focus.               *
* Copyright (C) 1990-2008                                    *
* by Livermore Software Technology Corp. (LSTC)              *
* All rights reserved                                        *
 contracting memory to           1 beginning of keyword reader
 expanding   memory to       21002
 expanding   memory to     1991996
 expanding   memory to     5048828
 expanding   memory to     5078828
 expanding   memory to     5192300
 expanding   memory to     5216549
 expanding   memory to     5907669
 expanding   memory to     6598789
 expanding   memory to     6619185
 expanding   memory to     6949490
 expanding   memory to     7276695
 expanding   memory to    10875950
 expanding   memory to    11212067
 expanding   memory to    14237267
 expanding   memory to    14564472  Memory required to process keyword     :     14564472
 contracting memory to           1 end of keyword reader LS-DYNA will perform a structural only analysis
                         ls-dyna ls971s.47756 R3.2.1  date 09/18/2008 E r r o r   t e r m i n a t i o n
 s t o r a g e   a l l o c a t i o n   Memory required to complete solution   :     14564472
 Additional dynamically allocated memory:            0
                                   Total:     14564472 T i m i n g   i n f o r m a t i o n
                        CPU(seconds)   %CPU  Clock(seconds) %Clock
  Initialization ....... 0.0000E+00    0.00     3.7000E-02  100.00
  Element processing ... 0.0000E+00    0.00     0.0000E+00    0.00
  Binary databases ..... 0.0000E+00    0.00     0.0000E+00    0.00
  ASCII database ....... 0.0000E+00    0.00     0.0000E+00    0.00
  Contact algorithm .... 0.0000E+00    0.00     0.0000E+00    0.00
  Contact entities ..... 0.0000E+00    0.00     0.0000E+00    0.00
  Rigid bodies ......... 0.0000E+00    0.00     0.0000E+00    0.00
  Implicit Nonlinear ... 0.0000E+00    0.00     0.0000E+00    0.00
  Implicit Lin. Alg. ... 0.0000E+00    0.00     0.0000E+00    0.00
  T o t a l s            0.0000E+00    0.00     3.7000E-02  100.00 Problem time       =    0.0000E+00
 Problem cycle      =         0
 Total CPU time     =         0 seconds (   0 hours  0 minutes  0 seconds)
 CPU time per zone cycle  =         0 nanoseconds
 Clock time per zone cycle=         0 nanoseconds Number of CPU's    1
 NLQ used/max     136/  136
 Start time   05/29/2020 00:13:06
 End time     05/29/2020 00:13:13
 Elapsed time       7 seconds(  0 hours  0 min.  7 sec.) for       0 cycles
各位大神我想问一下,我点击bat运算后就出现这个闪退了是什么情况
2020年5月29日
lqs10620
pandongcsu 兄弟
你的问题很容易解决
两个办法
1:在启动时候coustompreferce里面第一项调大存储设置
2:通过关键字*control—memory设置
希望对你有用
2010年5月28日
pandongcsu
Input file: E:\潘东\例子\C5-1.k
Memory size from default : 20000000
expanding memory to 20000000 starting ls-dyna
* This is the LS-DYNA Explicit Finite Element code. *
* results. *
* Copyright (C) 1990-2006 *
expanding memory to 20160
expanding memory to 152402
expanding memory to 2012882
expanding memory to 2042882
expanding memory to 2102882
expanding memory to 2514672
expanding memory to 2922112
expanding memory to 3764052
expanding memory to 3785025
expanding memory to 3805998
expanding memory to 3826971
expanding memory to 5642451
expanding memory to 5663424
expanding memory to 5685372
Memory required to process keyword : 5685372
C5-1.K
ls-dyna ls971s.7600.398 date 08/17/2006
expanding memory to 2601 material, node and element data
expanding memory to 13954 material properties
expanding memory to 1133125 element data
expanding memory to 3386993 user control for contact interfaces
expanding memory to 3386997 for boundary cond. vectorization
expanding memory to 3689553 nodal data
expanding memory to 3790413 arbitrary element numbering input
contracting memory to 3414629 spc cards
expanding memory to 7402825 process element material data
expanding memory to 7404826 load curve data
contracting memory to 7403035 rigidwall definitions
expanding memory to 7430110 nodal constaint sets
expanding memory to 8236157 contact interfaces
expanding memory to 9185843 mass scaling with ale
expanding memory to 9248762 ALE neighboring info
expanding memory to 22696284 ALE multimaterial storage
*** Error Memory is set 2696284 words short
Current memory size 20000000
Increase the memory size by one of the following
where #### is the number of words requested:
1) On the command line set - memory=####
2) In the input file define memory with *KEYWORD
i.e., *KEYWORD #### or *KEYWORD memory=####
Initialization ....... 0.0000E+00 0.00 0.0000E+00 0.00
T o t a l s 0.0000E+00 0.00 0.0000E+00 0.00
Problem cycle = 0
Number of CPU's 1
NLQ used/max 96/ 96
Start time 04/22/2010 08:36:22
End time 04/22/2010 08:36:29
2010年4月22日
crazyfaloter
请教楼主 由于小弟是新手 在相关设置上面还很陌生
我主要是作一个锥形尖头戳破薄膜的主题,锥形头视为刚体,
并在Z方向施一负载,小弟在跑结果时,不管怎么调整参数
,尖头都无法戳破薄膜,不知道是材料还元素设置错误,已
上传附件,麻烦楼主指点指点,大家一起来练习~
2010年4月12日
h01huang
楼主能不能帮忙给个——SimWe仿真论坛---的邀请码!
在这不胜感激了!
特想注册,没有邀请码
楼主帮个忙啊发到我邮箱h01huang@163.com 或QQ4378084
3Q了!!!
2010年3月31日
h01huang
在这不胜感激了!
想注册,没有邀请码,
楼主帮个忙啊
3Q了!!!
2010年3月31日
kingdom0822
敬请版主解答呀,谢谢啦
2010年3月29日
kingdom0822
忘了说一下,模型区域是长宽高分别为60m、60m和8m的长方体区域,因因此,第一个爆炸的药包距离发生异常变化的网格至少有几十米。药包采用二号岩石炸药,每个药包重20kg。
2010年3月28日
kingdom0822
如上图,利用九个药包进行微差爆炸。炸药散布在场地周围。用ls-prepost看结果,发现有些土体区域在炸药还没有爆炸的时候就已经产生了巨大的网格变形和压力,甚至比已经爆炸的土体的变形和压力还要大,而这些区域一般都是远离炸药单元的纯土体啊!理论上不受外力,怎么会有证明强烈的反应呢。不知道大家觉得会是什么原因?困惑中,还望大家答疑解惑k文件较大,发送附件不方便。如果各位还需要些什么信息才能够对我的问题做出解答的话,我再继续发。
2010年3月28日
kingdom0822
谢谢版主指教!
做土体中爆炸分析的时候也遇到个问题。做的是个在一块场地进行的微差爆炸,炸药散布在场地周围,依次爆炸。用ls-prepost看结果,发现有些土体区域在炸药还没有爆炸的时候就已经产生了巨大的网格变形和压力,甚至比已经爆炸的土体的变形和压力还要大,而这些区域一般都是远离炸药单元的纯土体啊!理论上不受外力,怎么会有证明强烈的反应呢。不知道大家觉得会是什么原因?困惑中,还望大家答疑解惑
网格变形和药包位置图如下,第一个药包刚发生爆炸,原处的土体单元就发生较大变形且盈利较大,这是不符合实际的,因为此时其他药包并没有任何变化
2010年3月28日
