看看这个命令流问题出在哪里?
浏览:64318 回答:4
最近在做ansys疲劳分析,下列命令做到最后疲劳分析时,都会出现问题,问题提示为:
N values missing, out of order, non-positive. The FTCA command is ignored.
大家帮忙看看这个命令流问题出在最后的哪里?拜托了:share:
/fini
/cle
/filname,exm11.3
/units,si
/gra,power
/gst,on
/plo,info,3
/plo,date,0
/color,pbak,off
/rgb,index,100,100,100,0
/rgb,index,80,80,80,13
/rgb,index,60,60,60,14
/rgb,index,0,0,0,15
/dev,font,1,courier*new,400,0,-19,0,0,,,
/plopts,info,3
/triad,orig
/replot
/dev,font,2,courier*new,400,0,-19,0,0,,,
/prep7
et,1,plane42
keyopt,1,3,0
mp,ex,1,1e6
mp,nuxy,1,0.3
k,1,,0.5
k,2,,10
k,3,,-0.5
k,4,,-10
k,5,0,0,0
l,1,2
l,3,4
circle,5,0.5
ldele,4,5.0
k,10,5,10
k,11,5,-10
lstr,2,10
lstr,10,11
lstr,11,4
nummrg,all
al,all
lesize,3,,,10
lesize,6,,,10
lesize,1,,,20
lesize,2,,,20
lesize,4,,,10
lesize,7,,,10
lesize,5,,,40
amesh,1
alls
/solu
antype,0
csys,0
/color,u,blue
nsel,s,loc,y,-10
d,all,all
sfl,4,pres,30
alls
/post1
ftsize,1,1,2
/sol
solve
/post1
fsnode,102,1,1
/solu
sfl,4,pres,-30
solve
/post1
fsnode,102,1,2
fp,1,100,200,500,1000,1500,2000
fp,7,1E4,1E5,1E6,2E6,3E6,5E6
fp,13,6E6,7E6,8E6,9E6,1E6,11E6
fp,19,12E6,15E6
fp,21,150,120,110,100,95,90
fp,27,85,80,75,70,65,60
fp,33,55,50,45,40,35,30
fp,39,29,25
fl,1,102,2,2,2,loc1
fe,1,10000,2,eve1
ftcalc,1
(4)
feifei
/fini
/cle
/filname,exm11.3
/units,si
/gra,power
/gst,on
/plo,info,3
/plo,date,0
/color,pbak,off
/rgb,index,0,0,0,15
/plopts,info,3
/triad,orig
/replot
/prep7
et,1,plane42
keyopt,1,3,0
mp,ex,1,1e6
mp,nuxy,1,0.3
k,1,,0.5
k,2,,10
k,3,,-0.5
k,4,,-10
k,5,0,0,0
l,1,2
l,3,4
circle,5,0.5
ldele,4,5.0
k,10,5,10
k,11,5,-10
lstr,2,10
lstr,10,11
lstr,11,4
nummrg,all
al,all
lesize,3,,,10
lesize,6,,,10
lesize,1,,,20
lesize,2,,,20
lesize,4,,,10
lesize,7,,,10
lesize,5,,,40
amesh,1
alls
/solu
antype,0
csys,0
/color,u,blue
nsel,s,loc,y,-10
d,all,all
sfl,4,pres,30
alls
/post1
ftsize,1,1,2
/sol
solve
/post1
fsnode,102,1,1
/solu
sfl,4,pres,-30
solve
/post1
fsnode,102,1,2
fp,13,6E6,7E6,8E6,9E6,10E6,11E6
fp,19,12E6,15E6
fp,39,29,25
fl,1,102,2,2,2,loc1
FSNODE,102,1,1
FS,102,1,2,0,0,0,0,0,0
fe,1,10000,2,eve1
ftcalc,1
这是我做的,完全可以运行
2010年2月19日
邹正刚
几个 fp 命令中:
中,9E6 后面的 1E6 应该改为 10E6 吧?不知是否这个原因?
2010年2月7日
bys0007
你这话等于没说,我要是知道问题出在哪,我还用得着问你们嘛,正是因为不知道才求教各位的呀:share:
2010年1月25日
Liuyili
不是有提示吗?FTCA这个命令无效,那这个命令有关的参数也没有几个,你在help中找到这个命令的说明,意义对照你上面的参数的设置,不就可以改过来了吗?
就从ftcalc,1你的这个命令入手!
2010年1月25日
