有了这些,大家找资料方便
浏览:44276
国外大学评出的转子动力学重要期刊
国外大学评出的 转子动力学重要期刊
Diesel and Gas Turbine Worldwide
International Journal of Rotating Machinery
Mechanical Engineering
Modern Power Systems
Sulzer Technical Review
Teploenergetika
Transactions of the ASME - Journal of Biomechanical Engineering
Transactions of the ASME - Journal of Dynamic System, Measurement
Transactions of the ASME - Journal of Engineering for Gas Turbines and Power
Transactions of the ASME - Journal of Fluids Engineering
Transactions of the ASME - Journal of Tribology
Transactions of the ASME - Journal of Turbomachinery
Turbomachinery International
Most important foreign journals in the library of the Institute of Turbomachinery Technical University of Lodz
