我的tosca和abaqus出现这个情况,大家看看是怎么回事~?~?
浏览:131735 回答:4
Additional error info:
TOSCA Structure Control : f:\Program Files\TOSCA621\bin\os_winnt\tosca_perl.exe
TOSCA Structure Arguments : ice -type all -solver abaqus -out user
Solver : abaqus
Cycle :
Operating system : MSWin32
ERROR in TOSCA Structure-module:
| TOSCA Structure.fem_include |
Error occured during optimization
Module call: "f:\Program Files\TOSCA621/bin/fem_include" -solver abaqus Job-1.inp
Please check the corresponding ERROR log Files
TOSCA job finished with an error
return value: 2
Tosca Process ID: unknown
我的软件是盗版的~~
(4)
flyford
请问楼主,哪里可以下载到tosca呢?能否发一份给我呢,xiaoxiao.xia@qq.com,谢谢
2011年7月19日
qq
基本上属于安装问题。路径等环境变量没设对。
2011年1月17日
zhangkuan2007
! Parameter file for TOSCA Optimization Task
! Created with TOSCA Structure.gui 6.2.1
! Date : Fri Sep 17 15:19:05 CST 2010
! Author :
! Remarks :
! Description :
FEM_INPUT
ID_NAME = MY_INPUT_FILES
FILE = Job-1.inp
END_
DV_TOPO
ID_NAME = MY_DV_TOPO
EL_GROUP = ALL_ELEMENTS
END_
DVCON_TOPO
ID_NAME = MY_DVCON_TOPO
CHECK_TYPE = FROZEN
END_
DRESP
ID_NAME = MY_DRESP
DEF_TYPE = SYSTEM
TYPE = VOLUME
GROUP_OPER = Max
END_
OBJ_FUNC
ID_NAME = MY_OBJ_FUNC
TARGET = MIN
END_
OPTIMIZE
ID_NAME = MY_OPTIMIZATION_TASK
OBJ_FUNC = MY_OBJ_FUNC
DV = MY_DV_TOPO
STRATEGY = TOPO_CONTROLLER
END_
SMOOTH
ID_NAME = mySmooth
ISO_VALUE = 0.3
TASK = iso
SELF_INTERSECTION_CHECK = iterative
OUTPUT_SURFACE = both
FORMAT = vtf
FORMAT = inp
END_
INCLUDE, uf_group_vrml.mac
INCLUDE, uf_topo_vrml.mac
EXIT
期待高手!
2010年9月17日
zhangkuan2007
starting job: ice ...please wait
| _______ ____ _____ _____ |
| |__ __| / __ \ / ____| / ____| /\ |
| | | | | | || (___ | | / \ |
| | | | | | | \___ \ | | / /\ \ |
| | | | |__| | ____) || |____ / ____ \ |
| |_| \____/ |_____/ \_____|/_/ \_\ |
| _____ _ _ |
| / ____| | | | |
| | (___ | |_ _ __ _ _ ___| |_ _ _ _ __ ___ |
| \___ \| __| '__| | | |/ __| __| | | | '__/ _ \ |
| ____) | |_| | | |_| | (__| |_| |_| | | | __/ |
| |_____/ \__|_| \__,_|\___|\__|\__,_|_| \___| |
| Starting: OPTIMIZATION CONTROL TOSCA Structure.control |
| TOSCA Structure by FE-DESIGN GmbH |
| TOSCA Structure.topo, TOSCA Structure.shape and |
| TOSCA Structure.bead are registered trademarks and service |
| marks of the FE-DESIGN GmbH |
| Copyright(c) 2008 by FE-DESIGN GmbH, all rights reserved |
| PERL execution control |
| Version 6.2.1 |
| FE-DESIGN GmbH, Karlsruhe, Germany |
| http:://www.fe-design.de |
| Build: 17.02.09 |
TOSCA Structure Time information 17.09.2010 at 16:12:13
Optimization runs on a MSWin32 system
| READING TOSCA Structure CONFIGURATION |
All backslashes "\" are replaced with forward slashes "/" from file: f:\Program Files\TOSCA621/bin/tosca_ctrl.cfg
Nr of lines : 1
Creating temporary file with changes: ./temp_tosca_ctrl.cfg
Reading TOSCA Structure Configuration file : ./temp_tosca_ctrl.cfg
... Reading TOSCA Structure 6.2.1 Configuration
Deleting "./temp_tosca_ctrl.cfg"
Actual settings for optimization job :
actual working dir : D:/ice/ABAQUS 6.9
environment TOSCA : f:\Program Files\TOSCA621
environment HOME :
jobname : ice
fe-input File : Job-1.inp
parameter file : ice.par
fe_solver : abaqus
fe_solver_exe : "C:/Program Files/ABAQUS/Commands\abaqus.bat"
fe_solver_cmdline : job=__FE_MODEL__ analysis interactive
opt_type : all
Prep-module: "f:\Program Files\TOSCA621/bin/tosca_prep"
Opt -module: "f:\Program Files\TOSCA621/bin/tosca_opt"
Current Directory : D:/ice/ABAQUS 6.9
Jobname : ice
Workdir : D:/ice/ABAQUS 6.9/ice
| TOSCA Structure COMMAND_SHELL ERROR
Solver : abaqus
Cycle :
return value: 2
2010年9月17日
