SUPERFORM-2005的安装问题
浏览:109608 回答:1
破解说明如下:
1. unrar crack.rar to c:\flexlm
2. edit c:\flexlm\msc2005.dat, replace <name> with your host name, save it.
3. run lmtools.exe, configuration using service, then click
congfig service tab, set 'path to lmgrd.exe' with C:\flexlm\LMGRD.EXE,
set 'path to the license file' with C:\flexlm\msc2005.dat, select
'use services', then click 'save service' button. now click
start/stop/reread tab, click start server button. ok. now
flexlm service should be start.
4. set the enviroment string: LM_LICENSE_FILE=1700@<your hostname>
dont forget to replace <your hostname> with your true hostname:)
5. Install MSC products, when asked for license, use 1700@<your hostname>
Enjoy this fine app:)
ZWT 2005
在到第三步最后保存时提示错误,如图。
不知如何解决,各位帮忙给看看。
wlft2000
问题已解决 service name的问题 名字应该为flexlm
2010年10月3日
