又是体网格划分的问题
浏览:94911 回答:1
总体模型是:一个高500um的圆柱体1上还有一个高60nm的相同半径的圆柱体2。两圆柱体是放一起的。由于高度差别很大,网格划分时出现这种情况:
Verify:
232 angles less than 2.5 degrees found in triangle facets of volume 1,with smallest angle =0.1.poor element quality or mesh failure may result .do you want to continue?
should the vmes command be executed?
yes no
求大神指点,这种对尺寸相差很大的不同体积进行网格划分,该如何操作啊?望不吝赐教啊
Verify:
yes no
