求助:外部可压缩流问题
浏览:62934
小生做的是一个外部可压空气动力学问题。郁闷的是,在点击calculate时瞬间就
calculate complete了,没有计算就完成了,不知道问题出在哪里。搞的我好郁闷,
请各位高手大侠指点迷津,帮忙看看问题出在哪里。多谢多谢!!!(note:在case
check的solver中提示:Review reference values for non-dimensionalized force
coefficients computed with force monitors.其他选项卡则没有提示。)
设置情况如下:
General: 默认
Models:添加energy方程、viscous model:spalart-Allmaras(1 eqn)
Air:ideal-gas、viscosity为Sutherland(三参数)
Boundary Conditions:pressure-far-field 和 wall 。pressure-far-field情况为 Gauge
Pressure.=0;Number=0.85;X-Component of Flow Direction=0.9945 Y-
Component of Flow Direction=0.1045 Specification Method:Turbulent Viscosity
Ratio=10
Operating Conditions:Operating Pressure=101325
Reference Values:默认生成。
Solution Methods:scheme取为coupled,Density、momentum、modified turbulent
viscosity、energy皆为Second order upwind
Solution Controls:Courant Number=200 ;0.5 =Density in the Under-Relaxation
Factors ; 0.9 =Modified Turbulent Viscosity in the Under-Relaxation Factors.
Solution Initialization:默认生成。
