关于ansys使用内存问题
浏览:186787
我用布尔运算建模时提示the initial memory allocation(-m)has been exceeded.Supplemental memory allocations are being used.看网上的说法是内存的问题,我在use custom memory setting中将total workplace增大了,database减小了,但是老是死机(程序未响应),这种情况应该怎么处理?哪位大虾指点一下,谢谢!
