请教达人这些message是什么意思
浏览:71088
我让机构仿真运动的时候message window出现以下信息,我不确定还有什么问题,请达人指教:
“WARNING: The data set is kinematically determinate. However, a dynamic analysis
has been requested. A kinematic analysis with the SIMULATE/KINEMATICS
command would be more efficient and possibly more accurate for some of
the computed quantities.
As requested, the simulation will continue with a dynamic analysis.”
