Procast在多核处理器中运行失败
浏览:177277
多核环境设置正确,运行平台win7/x64/4核/8G。从 Procast 提示中看出模型已按并行处理方式做了分割,但就是不能进一步计算。
E:\CADCAM\PROCAST\C_Tube>set MPI_ROOT=d:\PROGRA~1\ESIGRO~1\ProCAST\2009.1\HPMPI
E:\CADCAM\PROCAST\C_Tube>"d:\PROGRA~1\ESIGRO~1\ProCAST\2009.1\HPMPI\bin\mpirun"
-np 4
-e LD_LIBRARY_PATH="d:\PROGRA~1\ESIGRO~1\ProCAST\2009.1\HPMPI\bin" -e MP
I_WORKDIR="E:\CADCAM\PROCAST\C_Tube" -e ProCAST20091="d:\PROGRA~1\ESIGRO~1\ProCA
ST\2009.1"
"d:\PROGRA~1\ESIGRO~1\ProCAST\2009.1\bin\64_exe\procastDMP64.exe" C
_tube_stress
HP-MPI licensed for ESI-Group.
ProCAST Version 2009.1, Parallel, Compiled on Jul 24 2009 at 10:11:45
Copyright ESI Group (France) 2004-2007
Executable adapted for HP-MPI!
icc Intel(R) C Compiler for Intel(R) EM64T-based applications Version 9.1 used!
Running on 4 processors
The DMP_FLOW module license will expire in -42 days
The DMP_THERM module license will expire in -42 days
The DMP_STRESS module license will expire in -42 days
The THERM module license will expire in -42 days
The FLOW module license will expire in -42 days
The STRESS module license will expire in -42 days
optimal communication in use.
XYZ Cut:
597
Balance:
1.012 [64 253 4]
Partitioning a graph of size 253 serially
Final 4-way CUT:
428
Balance: 1.012
avg: 1.012
XYZ Cut:
603
Balance:
1.012 [64 253 4]
Final 4-way CUT:
428
Balance: 1.012
avg: 1.012
XYZ Cut:
1731
Balance:
1.001 [459 1834 4]
Partitioning a graph of size 1834 serially
Final 4-way CUT:
462
Balance: 1.001
avg: 1.001
MPI Application rank 1 exited before MPI_Finalize() with status -1073740940
E:\CADCAM\PROCAST\C_Tube>PAUSE
请按任意键继续 . . .
