abaqus 提交报错
浏览:70442 回答:2
Surface assembly__pickedsurf43 can only have coupled temperature displacement underlying elements
Surface definition assembly__pickedsurf43 not found.
The surface assembly__pickedsurf43 has not been located
mafuyin
你肯定定义了一个不需要的面,你找找删掉。
2011年6月8日
0742823218
1 nodes lie on the axis of their cylindrical transformation systems. The local coordinate systems at these nodes are not well-defined. The nodes have been identified in node set WarnNodeCylTransSys.
The option *boundary,type=displacement has been used; check status file between steps for warnings on any jumps prescribed across the steps in displacement values of translational dof. For rotational dof make sure that there are no such jumps. All jumps in displacements across steps are ignored
Finite rotation boundary condition specified in multistep three-dimensional analysis. Type=velocity should be used
Boundary conditions are specified on inactive dof of 657 nodes. The nodes have been identified in node set WarnNodeBCInactiveDof.
2011年6月1日
