执行 CFX solver 出现错误讯息?????
浏览:94358 回答:1
请教高手如何解决????
The ANSYS CFX solver could not be started, or exited with return code 255:
. No results file has been created.
This run of the CFX-14.0 Solver started at 08:37:39 on 04 Jan 2012 by
user user on USER-PC (intel_xeon64.sse2_winnt) using the command:
"D:\Program Files\ANSYS Inc\v140\CFX\bin\perllib\cfx5solve.pl" -batch
-ccl runInput.ccl -fullname "Fluid Flow CFX_006"
Setting up CFX Solver run ...
rememberit_xyz
不知道您解决了没有。我觉得可能是软件破解的问题。重启电脑,不要设并行计算试试。
2012年1月11日
