首页
学院
直播
问答
悬赏
全部悬赏
发布悬赏
专家入驻
会议
社区
CAE工程师认证
CAE服务
搜索
发布
注册
登录
求指导~(建模命令流 及结果)
浏览:39591
回答:1
allsel,all
nummrg,all,,,,low
numcmp,all
ANSYS
CAE
结构CAE
6singma
实体模型可否在分析步中改变
关注问题
邀请回答
我来回答
默认
最新
405478426
finish
/clear,start
/filname,zuniqi
/title,zuniqi
/prep7
/units,mks
et,1,solid5,3
et,2,mesh200,6
mp,dens,1,8000
mp,perx,1,8000
mp,pery,1,8000
mp,perz,1,5400
mp,kxx,1,1
mp,murx,1,1
mp,nuxy,1,0.32
tb,anel,1,,,1
tbdata,1,32.8e-12,10e-12,10e-12,0,0,0
tbdata,7,32.8e-12,10e-12,0,0,0
tbdata,12,40.1e-12,0,0,0
tbdata,16,200e-11,0,0
tbdata,19,160e-11,0
tbdata,21,160e-11
tb,piez,1,,,1
tbdata,1,0,0,-290e-10
tbdata,4,0,0,-290e-10
tbdata,7,0,0,1035e-10
tbdata,10,0,0,0
tbdata,13,0,450e-10,0
tbdata,16,450e-10,0,0
k,1,0,0,0,
allsel
cyl4,0,0,12e-3,,19.5e-3
adele,1
lstr,4,8
lstr,7,2
lstr,5,6
lstr,9,3
allsel,all
lplot
a,4,8,9,3
a,4,5,6,8
a,5,2,7,6
a,2,3,9,7
allsel,all
nummrg,all,,,,low
numcmp,all
lsel,s,length,,0.01885
lesize,all,,,16,1,,,,1
lsel,s,length,,0.03063
lsel,s,length,,0.0075
lesize,all,,,6,1,,,,1
type,2
allsel
mshkey,1
amesh,all
k,50,0,0,-0.09
l,1,50
allsel
type,1
extopt,esize,18,0,
extopt,aclear,0
extopt,attr,0,0,0
mat,1
esys,0
esla,r
asel,s,,,1,4
vdrag,all,,,,,,13
eplot
/view,1,1,1,1
/ang,1,270,xm,0
/replot
nsel,s,loc,z,0
cm,n_bot,node
cp,1,volt,all
*get,n_bot,node,0,num,min
nsel,s,loc,z,-90e-3
cm,n_top,node
cp,2,volt,all
*get,n_top,node,0,num,min
nsel,all
d,n_bot,volt,0
d,n_top,volt,300!陶瓷管上下表面施加恒定电压
et,3,solid92 !!之上的命令完全没有问题,剩余体均用此材料
mp,ex,3,210e9
mp,prxy,3,0.3
!tb,bkin,3,1,2
!tbtemp,0
!tbdata,1,235,4.12e3,,,,
!mp,ex,4,206e3!第四种材料 可能有问题无用
!mp,prxy,4,0.3
!tb,bkin,4,1,2
!tbtemp,0
!tbdata,,940,4.12e3,,,,
cylind,0.011,0.05,0,0.004
vgen,2,5,,,,,0.02
vgen,2,5,6,,,,-0.114
block,-0.25,0.35,-0.12,0.12,-0.102,-0.094
block,-0.25,0.35,-0.12,0.12,0.004,0.012
block,-0.35,0.25,-0.06,0.06,-0.11,-0.102
block,-0.35,0.25,-0.06,0.06,0.012,0.02
cylind,0,0.02/2,0.004,0.012
vgen,2,13,,,-0.21,-0.08
vgen,2,13,,,-0.21,0.08
vgen,2,13,,,0.21,-0.08
vgen,2,13,,,0.21,0.08,,,,1
vgen,2,13,16,1,0,0,-0.106
cylind,,0.011,0.004,0.012
vgen,2,21,,,,,-0.106
block,-0.05,0.05,-0.012,0.012,0.012,0.02
vgen,2,23,,,,,-0.122
vsel,s,volu,,10,10,1
cm,bolt,volu
vsel,all
vsel,s,volu,,13,16,1
cm,endplate,volu
vsel,all
vsbv,bolt,endplate,keep,delete
vsel,s,volu,,9,9,1
cm,bolt1,volu
vsel,all
vsel,s,volu,,17,20,1
cm,endplate1,volu
vsel,all
vsbv,bolt1,endplate1,keep,delete
vsel,all
vsbv,11,24,keep,delete
vsbv,12,23,keep,delete
vsbv,10,22,keep,delete
vsbv,25,21,keep,delete
cylind,0,0.01,-0.102,0.012
vsel,all
cylind,0.011,0.03,0.024,0.044
vgen,2,17,,,,,-0.158
cylind,0.011,,-0.134,0.044
vglue,17,18,19
vglue,10,12,13,14,15,16
vsel,s,loc,z,0,0.008
2012年3月24日
评论
点赞
推荐阅读
【专题课程】ANSA HEXABLOCK六面体网格划分专题(完结)
Wonderful仿真
¥399
ALTAIR
免费
坚固型数据采集系统在恶劣环境条件下的测试应用
HBK测试与测量
免费
陈东陈
免费
B&K声级计全系列介绍及新款解密
HBK声学与振动
免费
场景仿真加速智能网联开发测试进程
海克斯康设计与仿真
免费
后保险杠低速碰撞分析
Crisby_Vectory_TrHo
¥70
Mathcad基本操作
HYT
¥89
活泼可男_matlab教学
¥10
CEL分析技术的理论与应用
赤子Sim
¥5
复杂电驱动系统动态实时功率测试
HBK测试与测量
免费
【推荐】基于DAMASK和ABAQUS的晶体塑性有限元分析全教程
枕流漱石
¥399
OptiStruct梁单元截面尺寸优化
谢晓峰
免费
应用VI-grade仿真解决方案进行赛车圈速仿真和性能优化
VI-grade中国
免费
Fluent中升力和阻力的计算
宁博士CAE团队
免费
热力学理论入门基础(上)
引垂思汀
¥30
隔热螺栓的优化仿真案例分享
钛闻软件
¥29
Creo/Proe曲面实战-摆钟高级曲面
creo/proe●一加一教育
¥16.8
北京华盛扬科技
¥9.9
用EVOLVE对接INSPIRE,加速产品迭代优化
咸鱼氮泵
免费
工程师
必备
项目客服
培训客服
平台客服
/clear,start
/filname,zuniqi
/title,zuniqi
/prep7
/units,mks
et,1,solid5,3
et,2,mesh200,6
mp,dens,1,8000
mp,perx,1,8000
mp,pery,1,8000
mp,perz,1,5400
mp,kxx,1,1
mp,murx,1,1
mp,nuxy,1,0.32
tb,anel,1,,,1
tbdata,19,160e-11,0
tbdata,21,160e-11
tb,piez,1,,,1
tbdata,10,0,0,0
k,1,0,0,0,
allsel
adele,1
lstr,4,8
lstr,7,2
lstr,5,6
lstr,9,3
allsel,all
lplot
a,4,8,9,3
a,4,5,6,8
a,5,2,7,6
a,2,3,9,7
allsel,all
nummrg,all,,,,low
numcmp,all
type,2
allsel
mshkey,1
amesh,all
k,50,0,0,-0.09
l,1,50
allsel
type,1
extopt,esize,18,0,
extopt,aclear,0
extopt,attr,0,0,0
mat,1
esys,0
esla,r
asel,s,,,1,4
vdrag,all,,,,,,13
eplot
/view,1,1,1,1
/ang,1,270,xm,0
/replot
nsel,s,loc,z,0
cm,n_bot,node
cp,1,volt,all
nsel,s,loc,z,-90e-3
cm,n_top,node
cp,2,volt,all
nsel,all
d,n_bot,volt,0
mp,ex,3,210e9
mp,prxy,3,0.3
!tb,bkin,3,1,2
!tbtemp,0
!mp,prxy,4,0.3
!tb,bkin,4,1,2
!tbtemp,0
vgen,2,5,,,,,0.02
cm,bolt,volu
vsel,all
cm,endplate,volu
vsel,all
vsel,s,volu,,9,9,1
cm,bolt1,volu
vsel,all
cm,endplate1,volu
vsel,all
vsel,all
vsel,all
vglue,17,18,19
