Gambit安装问题
浏览:157741
安装打开Gambit后出现错误错误代码如下:Warning : The current transport does not permit the attempted TCPIP connection. TRANS(SocketINETGetAddr): tnamebysocket() failedTRANS(SocketINETConnect): TRANS(SocketINETGetAddr) () failedTRANS(Open): transport open failed for tcp/localpc:0.0:0Unable to open displayexceed版本没问题,重装也不行。。。请问如何解决
