mu11
我按照上面的弄了。Ug还是老样子啊。请问有没有截图教程或者更全面一点的啊。
2012年6月3日
mu11
我按照上面的弄了。Ug还是老样子啊。请问有没有截图教程或者更全面一点的啊。:g
2012年6月3日
王毅
AutoForm的安装目录里有一个专门的模块,需要单独安装和授权的;
AutoForm_NX Interface 模块,具体的可以看看下面:
5.2.2. Installation
In order to use AutoForm´s NX interface you have to add one framework to your existing NX environment. This framework can be found on the DVD in the folder CATIA_NX.
There are several ways to carry out this procedure. Probably there is already a defined procedure in your company how to add plug-ins to your existing NX installation. The following instruction works for a standalone version of NX and has to be adapted to your NX maintenance concept.
o Create a new text file with the name UGEnv.txt in your installation directory. Insert the complete path of the framework as follows:
<AF_HOME_R3>\AFCAD_for_NX3-NX5_1.0-plusR3.1_Win32
(including the level above “application” and “startup”)
where “$AF_HOME_R3“ must be replaced by your AutoFormplus R3.1 installation directory (e.g. C:\ProgramFiles\AutoForm\AFplus\
R3.1\afhome)
Example of the complete path:
“C:\Program Files\AutoForm\AFplus\R3.1\afhome\AFCAD_for_NX3-NX5_1.0-plusR3.1_Win32”
o Create a system variable “UGII_CUSTOM_DIRECTORY_FILE“ pointing to the previously created text file. If this variable does already exist, add the line of file UGEnv.txt to the file pointed to by that variable.
o You can use the regular command ugraf.exe for launching NX.
2012年5月30日
