螺管永磁直流电磁分析?
浏览:167876 回答:2
请各位达人帮忙看一下是什么问题,感觉电磁力太小了?
/BATCH
/COM,ANSYS RELEASE 10.0 UP20050718 10:35:34 05/25/2010
RESUME,'gyf','db','.'
/COM,ANSYS RELEASE 10.0 UP20050718 10:35:35 05/25/2010
/PREP7
FINISH
/CLEAR,NOSTART
/COM,ANSYS RELEASE 10.0 UP20050718 10:36:09 05/25/2010
FINISH
/FILNAME,wyc,1
/BATCH
/COM,ANSYS RELEASE 10.0 UP20050718 10:37:46 05/25/2010
/PREP7
ET,2,PLANE53
ETDEL,1
ET,1,PLANE53
KEYOPT,1,1,0
KEYOPT,1,2,0
KEYOPT,1,3,1
KEYOPT,1,4,0
KEYOPT,1,5,0
KEYOPT,1,7,0
KEYOPT,2,1,2
KEYOPT,2,2,0
KEYOPT,2,3,1
KEYOPT,2,4,0
KEYOPT,2,5,0
KEYOPT,2,7,0
KDIST, 1, 33
CM,_Y,AREA
ASEL, , , , 2
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT, 5, , 1, 0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,AREA
ASEL, , , , 3
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT, 6, , 1, 0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,AREA
ASEL, , , , 1
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT, 3, , 1, 0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,AREA
ASEL, , , , 8
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT, 2, , 1, 0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,AREA
ASEL, , , , 4
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT, 4, , 1, 0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,AREA
ASEL, , , , 5
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT, 1, , 2, 0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
SMRT,6
SMRT,3
MSHAPE,0,2D
MSHKEY,0
FLST,5,6,5,ORDE,3
FITEM,5,1
FITEM,5,-5
FITEM,5,8
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
/PNUM,KP,0
/PNUM,LINE,0
/PNUM,AREA,1
/PNUM,VOLU,0
/PNUM,NODE,0
/PNUM,TABN,0
/PNUM,SVAL,0
/NUMBER,0
/PNUM,MAT,1
/REPLOT
/DIST,1,0.924021086472,1
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/DIST,1,1.08222638492,1
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
FLST,2,6,5,ORDE,3
FITEM,2,1
FITEM,2,-5
FITEM,2,8
ARSCALE,P51X, , ,0.001,0.001,1, ,0,1
/AUTO,1
/REP,FAST
EPLOT
ESEL,S,MAT,,5
EPLOT
/REP,FAST
CM,arm,ELEM
ALLSEL,ALL
EPLOT
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
ESEL,S,MAT,,5
EPLOT
FMAGBC,'ARM'
ALLSEL,ALL
EPLOT
FLST,5,6,5,ORDE,3
FITEM,5,1
FITEM,5,-5
FITEM,5,8
ASEL,S, , ,P51X
APLOT
ASEL,S, , , 5
APLOT
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
ASUM, DEFAULT
ASUM, DEFAULT
*GET,acond,AREA, ,ATTR,MAT
ASUM, DEFAULT
/REP,FAST
/REP,FAST
/REP,FAST
*GET,acond,AREA, ,AREA
*GET,xcond,AREA,,CENT,X, , , ,
*SET,cf,2*3.14*0.171e-7*xcond*1250**2/20/acond
/REPLOT,RESIZE
/REPLOT,RESIZE
R,1,acond,1250,0,0,cf,
RLIST, ALL
NSLE,S
NSEL,ALL
NSLE,S
/REP,FAST
NPLOT
/REP,FAST
ESEL,S,MAT,,1
EPLOT
NSLE,S
NSLE,S
FLST,4,679,1,ORDE,6
FITEM,4,35
FITEM,4,-38
FITEM,4,351
FITEM,4,-466
FITEM,4,912
FITEM,4,-1470
CP,1,CURR,P51X
CM,coil,ELEM
ALLSEL,ALL
APLOT
NSEL,S,EXT
NPLOT
FLST,2,208,1,ORDE,24
FITEM,2,1
FITEM,2,-2
FITEM,2,5
FITEM,2,9
FITEM,2,-10
FITEM,2,13
FITEM,2,19
FITEM,2,22
FITEM,2,-23
FITEM,2,28
FITEM,2,43
FITEM,2,-140
FITEM,2,147
FITEM,2,-185
FITEM,2,261
FITEM,2,-292
FITEM,2,298
FITEM,2,-310
FITEM,2,344
FITEM,2,-350
FITEM,2,514
FITEM,2,-520
FITEM,2,817
FITEM,2,1471
D,P51X,AZ,0
ALLSEL,ALL
EPLOT
ASEL,S, , , 5
APLOT
FLST,2,1,5,ORDE,1
FITEM,2,5
BFA,P51X,VLTG,4.5, ,
FLST,2,1,5,ORDE,1
FITEM,2,5
FINISH
/SOL
/GST,1
MAGSOLV,0,3,0.001, ,25,
/REP,FAST
ALLSEL,ALL
APLOT
/REP,FAST
ANTYPE,0
FINISH
/PREP7
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,RSVX,1,,0.17100e-07
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,RSVX,2,,0.17100e-07
FINISH
/POST1
FINISH
/SOL
FINISH
/POST1
PLF2D,27,0,10,1
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
FMAGSUM,'ARM'
liu2008100712
:strong:,能否加我QQ:932267039
2013年3月13日
liu2008100712
我的QQ932267039,能加我吗
2013年3月10日
