fatigue计算结果出问题
浏览:119065 回答:1
fatigue疲劳计算结果出现$# Warning reported from application APP PFATIGUE# The "Current spectrum" as been set to "fatigue spectrum" for life contouring. A "log_range" has also been created. Change them under "Display/Spectrums(Ranges)" if necessary.是什么问题?
dongdoudou88
我的也是这么一个问题啊。楼主解决了吗?求指教
2012年11月27日
