谁能帮我解释一下出现warning的原因
浏览:74034 回答:3
Date: 10/30/2012 Time: 21:13:18
___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version: 970 Date: 01/10/2005 |
| Revision: 5434a Time: 18:01:01 |
| Features enabled in this version: |
| ANSYS Database format |
| Shared Memory Parallel |
| Licensed to: |
| Platform : |
| OS Level : WINDOWS XP |
| Hostname : FREESKYC-1D9860 |
| Precision : Single precision (I4R4) |
| Unauthorized use infringes LSTC copyrights |
Input file: C:\PROGRA~1\ANSYSI~1\RC-COL~1.K
The native file format : 32-bit small endian
Memory size from default : 8500000
expanding memory to 8500000
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Explicit Finite Element code. *
* Neither LSTC nor the authors assume any responsibility for *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2005 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
contracting memory to 24720
expanding memory to 50476
expanding memory to 98716
expanding memory to 146086
expanding memory to 206086
expanding memory to 237104
expanding memory to 298612
expanding memory to 343378
LS-DYNA will perform a structural only analysis
ALALYSIS OF A RC-COLUMN
ls-dyna (version 970 ) date 01/10/2005
expanding memory to 2580
expanding memory to 13935
contracting memory to 10054
expanding memory to 107617
expanding memory to 108176
expanding memory to 110597
expanding memory to 185798
expanding memory to 187809
contracting memory to 186859
expanding memory to 189658
expanding memory to 205638
contracting memory to 200626
expanding memory to 213156
expanding memory to 213865
expanding memory to 221653
contracting memory to 214556
expanding memory to 214601
contracting memory to 214601
expanding memory to 214681
contracting memory to 214681
expanding memory to 214684
contracting memory to 214684
*** Warning Massless nodes
The following massless nodes were found
node # 2
node # 3
node # 4
node # 5
node # 6
node # 7
node # 8
node # 9
node # 10
node # 12
node # 22
node # 23
node # 25
node # 26
node # 27
node # 28
node # 29
node # 30
node # 31
node # 33
node # 34
node # 36
node # 37
node # 38
node # 39
node # 40
node # 41
node # 42
node # 44
node # 45
node # 47
node # 48
node # 49
node # 50
node # 51
node # 52
node # 53
node # 55
node # 56
node # 58
node # 59
node # 60
node # 61
node # 62
node # 63
node # 64
node # 66
node # 67
node # 69
node # 70
node # 71
node # 72
node # 73
node # 74
node # 75
node # 77
node # 78
node # 80
node # 81
node # 82
node # 83
node # 84
node # 85
node # 86
node # 88
node # 89
node # 91
node # 92
node # 93
node # 94
node # 95
node # 96
node # 97
node # 99
node # 100
node # 110
node # 112
node # 113
node # 114
node # 115
node # 116
node # 117
node # 118
node # 119
node # 120
node # 122
node # 123
node # 124
node # 125
node # 126
node # 127
node # 128
node # 129
node # 130
node # 131
node # 132
node # 133
node # 143
node # 144
node # 146
node # 147
node # 148
node # 149
node # 150
node # 151
node # 152
node # 154
node # 155
node # 157
node # 158
node # 159
node # 160
node # 161
node # 162
node # 163
node # 165
node # 166
node # 168
node # 169
node # 170
node # 171
node # 172
node # 173
node # 174
node # 176
node # 177
node # 179
node # 180
node # 181
node # 182
node # 183
node # 184
node # 185
node # 187
node # 188
node # 190
node # 191
node # 192
node # 193
node # 194
node # 195
node # 196
node # 198
node # 199
node # 201
node # 202
node # 203
node # 204
node # 205
node # 206
node # 207
node # 209
node # 210
node # 212
node # 213
node # 214
node # 215
node # 216
node # 217
node # 218
node # 220
node # 221
node # 231
node # 232
node # 233
node # 234
node # 235
node # 236
node # 237
node # 238
node # 239
node # 240
node # 241
node # 242
node # 243
node # 244
node # 245
node # 246
node # 247
node # 248
node # 249
node # 250
node # 251
node # 252
node # 253
node # 254
node # 264
node # 265
node # 267
node # 268
node # 269
node # 270
node # 271
node # 272
node # 273
node # 275
node # 276
node # 278
node # 279
node # 280
node # 281
node # 282
node # 283
node # 284
node # 286
node # 287
node # 289
node # 290
node # 291
node # 292
node # 293
node # 294
node # 295
node # 297
node # 298
node # 300
node # 301
node # 302
node # 303
node # 304
node # 305
node # 306
node # 308
node # 309
node # 311
node # 312
node # 313
node # 314
node # 315
node # 316
node # 317
node # 319
node # 320
node # 322
node # 323
node # 324
node # 325
node # 326
node # 327
node # 328
node # 330
node # 331
node # 333
node # 334
node # 335
node # 336
node # 337
node # 338
node # 339
node # 341
node # 342
node # 352
node # 353
node # 354
node # 355
node # 356
node # 357
node # 358
node # 359
node # 360
node # 361
node # 362
node # 363
node # 364
node # 365
node # 366
node # 367
node # 368
node # 369
node # 370
node # 371
node # 372
node # 373
node # 374
node # 375
node # 385
node # 386
node # 388
node # 389
node # 390
node # 391
node # 392
node # 393
node # 394
node # 396
node # 397
node # 399
node # 400
node # 401
node # 402
node # 403
node # 404
node # 405
node # 407
node # 408
node # 410
node # 411
node # 412
node # 413
node # 414
node # 415
node # 416
node # 418
node # 419
node # 421
node # 422
node # 423
node # 424
node # 425
node # 426
node # 427
node # 429
node # 430
node # 432
node # 433
node # 434
node # 435
node # 436
node # 437
node # 438
node # 440
node # 441
node # 443
node # 444
node # 445
node # 446
node # 447
node # 448
node # 449
node # 451
node # 452
node # 454
node # 455
node # 456
node # 457
node # 458
node # 459
node # 460
node # 462
node # 463
node # 473
node # 474
node # 475
node # 476
node # 477
node # 478
node # 479
node # 480
node # 481
node # 482
node # 483
node # 484
node # 485
node # 486
node # 487
node # 488
node # 489
node # 490
node # 491
node # 492
node # 493
node # 494
node # 495
node # 496
node # 506
node # 507
node # 509
node # 510
node # 511
node # 512
node # 513
node # 514
node # 515
node # 517
node # 518
node # 520
node # 521
node # 522
node # 523
node # 524
node # 525
node # 526
node # 528
node # 529
node # 531
node # 532
node # 533
node # 534
node # 535
node # 536
node # 537
node # 539
node # 540
node # 542
node # 543
node # 544
node # 545
node # 546
node # 547
node # 548
node # 550
node # 551
node # 553
node # 554
node # 555
node # 556
node # 557
node # 558
node # 559
node # 561
node # 562
node # 564
node # 565
node # 566
node # 567
node # 568
node # 569
node # 570
node # 572
node # 573
node # 575
node # 576
node # 577
node # 578
node # 579
node # 580
node # 581
node # 583
懒小兔UU
你好,我用dynaform计算的时候有时候也出现这种情况,咋回事呀。。
2014年11月12日
zyg86111887
节点上没赋予质量属性,设置质量属性啊,LS-dyna的默认设置中不是冲压仿真所需的参数啊。建议用DF作,默认设置时冲压所需的参数
2012年11月12日
王毅
没看出啥问题,建议发到ANSYS区或者ls-dyna区域
2012年10月31日
