求教高手,这是什么样的错误啊!
浏览:104818 回答:4
The executable C:\SIMULIA\Abaqus\6.11-1\exec\pre.exe aborted with system error code 5. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
提到:
I had same error code before. I reduced the analysis steps in History Output Requests and problem solved. You may want to give it a try.
