Solidworks模型导入ansys workbench时出现警告,望解惑!
浏览:169751
The following faces are higher order NURBS with many knots. These types of surfaces may lead to longer meshing times. If meshing time is long, changing your smoothing to low may help improve the meshing speed.
谢谢各位大侠!
