温度场导入求帮助!
浏览:102712
| 我先做了一个温度场计算,又做了一个荷载计算,在荷载里导入温度场时显示如下内容 A Memory Exception was caught while reading field data from the output database(ODB). Try decreasing the field output data in the ODB. If this is a 32 bit platform, try running the analysis on a 64 bit platform.解决不了,请多多帮忙! 导入温度场是不是就是建立一个预应力场填写如下图内容,在计算一遍就可以了 |
