ANSYS运行过程中出现警告没有活动的自由度及实常数的警告,求指点
浏览:35656
我做的是辐射热分析,用的是SHELL57单元,期间翻转了几个面的法线,运行过程中出现下面两个警告:
*** WARNING *** CP = 4.212 TIME= 10:18:12
Real constants on areas or elements that had the normal direction
reversed have not been adjusted. You should verify the resulting real
constants on any reversed areas or elements.
*** WARNING *** CP = 52.307 TIME= 10:22:21
There are no active degrees of freedom.
请教怎么解决问题?????非常感谢
请教怎么解决问题?????非常感谢
