ansys 错误
浏览:72264 回答:1
求助各位大侠啊,ANSYS 循环计算中出现错误计算终止了。
*** WARNING *** CP = 2497.966 TIME= 19:48:06
There are 2 small equation solver pivot terms.
*** ERROR *** CP = 2497.982 TIME= 19:48:06
The value of UY at node 95032 is 5.098300158E+09. It is greater than
the current limit of 1000000. This generally indicates rigid body
motion as a result of an unconstrained model. Verify that your model
is properly constrained.
ZYR
Y向产生刚体位移,检查约束及接触。
2013年4月5日
