- 技术邻 >
- CAE仿真 >
- HyperWorks
hypermesh中铝用什么材料卡片?
浏览:95766 回答:4
是MAT几大家知道吗?是铝,不是铝合金
HM-4010: Formatting Model for Analysis
中的截取,楼主可以参考,选取的铝的材料参数及卡片设置Step 5: Define a material collector named aluminum for the bracket.
This material is defined for the channel.
| 1. | Right-click in the white space of the Model Browser. |
| 2. | Select Create > Material. |
| 3. | For Name: enter aluminum. |
| 4. | Set Card image: to MAT1. |
| 5. | Make sure Card edit material upon creation is selected. |
| 6. | Click Create to create the material and edit it. |
| 7. | Click [E] and enter 7.0e4 in the field that appears. |
| 8. | Click [NU] and enter 0.33 in the field that appears. |
| 9. | Click return to exit the panel. |
非常感谢!
