运行错误 求解释
浏览:180122 回答:1
An error occurred during a write access to C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Administrator_Job-3_4056\Job-3_stdSolver.local_0 file. Check the disk space on your system.
The executable D:\SIMULIA\Abaqus\6.11-PR3\exec\standard.exe aborted with system error code 5. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
