求助 ABAQUS 纤维拔出仿真
浏览:126701 回答:7
No heat flow will occur between the slave and master pair (assembly_set-matrix_cns_, assembly_surf-fibre). Heat generated at the interface will not flow into either surface. If this is not desirable, consider defining the slave surface as type=element.
For contact pair (assembly_set-matrix_cns_-assembly_surf-fibre), adjustment was specified but no node was adjusted more than the adjustment distance = 2.22000e-16.
Abaqus IS UNABLE TO ESTIMATE AN AVERAGE INTERFACE ELEMENT LENGTH. THE WHOLE MODEL CHARACTERISTIC ELEMENT LENGTH IS USED INSTEAD.
这些怎么修改 求大神帮忙 不胜感激 新建文件夹.zip
学习一下,最近也在研究
