求大神帮我翻译一下命令
浏览:115536
445425122@163.com 或者直接发帖注释下 谢谢啦
/PREP7
R=0.1
L=1
W=1
H=0.5
ET,1,SOLID185
MP,EX,1,2.9E12
MP,PRXY,1,0.24
MP,EX,2,2.1E11
MP,PRXY,2,0.3
TB,BISO,1,1,2,
TBTEMP,0
TBDATA,,800E6,0,,,,
TB,BISO,2,1,2,
TBTEMP,0
TBDATA,,235E6,0,,,,
CYL4,0,0,R,0,0,-90
VROTAT,ALL, , , , , ,1,3,-90, ,
BLOCK,0,L/2,-R-H,-R,0,W/2,
ESIZE,0.02,0,
TYPE, 1
MAT, 1
VMESH,1
MAT, 2
VMESH,2
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
/GSAV,cwz,gsav,,temp
MP,MU,1,0.12
MAT,1
R,3
REAL,3
ET,2,170
ET,3,174
KEYOPT,3,9,0
KEYOPT,3,10,2
R,3,
RMORE,
RMORE,,0
RMORE,0
! Generate the target surface
ASEL,S,,,8
CM,_TARGET,AREA
TYPE,2
NSLA,S,1
ESLN,S,0
ESLL,U
ESEL,U,ENAME,,188,189
NSLE,A,CT2
ESURF
CMSEL,S,_ELEMCM
! Generate the contact surface
ASEL,S,,,2
CM,_CONTACT,AREA
TYPE,3
NSLA,S,1
ESLN,S,0
NSLE,A,CT2
ESURF
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,2
ESEL,A,TYPE,,3
ESEL,R,REAL,,3
/PSYMB,ESYS,1
/PNUM,TYPE,1
/NUM,1
EPLOT
ESEL,ALL
ESEL,S,TYPE,,2
ESEL,A,TYPE,,3
ESEL,R,REAL,,3
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
/GRES,cwz,gsav
CMDEL,_TARGET
CMDEL,_CONTACT
/MREP,EPLOT
/SOL
NLGEOM,1
DA,4,SYMM
DA,9,SYMM
DA,1,SYMM
DA,5,SYMM
DA,7,ALL
SFA,3,1,PRES,7.5e7
OUTRES,ALL,ALL,
TIME,1
AUTOTS,1
NSUBST,100,
KBC,0
SOLVE
