ansys求解出错
浏览:47650
建模,网格,施加力和约束都没有问题,一到求解就出问题了,An unknown error occurred during solution. Check the Solver Output on the Solution Information object for possible causes.
我看了Solution Information,上面说:
*** WARNING *** CP = 2.668 TIME= 20:12:31
File ds.dat does not exist.
The /INPUT command is ignored.
EXIT ANSYS WITHOUT SAVING DATABASE
NUMBER OF WARNING MESSAGES ENCOUNTERED= 1
NUMBER OF ERROR MESSAGES ENCOUNTERED= 0
我去文件夹下看了,ds.dat这个文件是存在的,而且我用记事本打开这个文件,里面也有东西的啊!
