铝合金板对接焊接残余应力模拟求助!!
浏览:31753 回答:1
铝合金板对接焊接残余应力模拟求助!!!我是新手~~希望可以得到大侠的帮助~~用6A02铝合金~~板的尺寸为250mm*150mm*8mm~~~~谢谢!!
dong1234
You can estimate it first, by the inner strength ans shrink of this material,
as the material is 8mm, the HAZ at the foot tip is critical, and the operation techniques are important.
2013年8月12日
