ABAQUS中利用seam计算应力强度因子时,在step中必须打开非线性吗?
浏览:180474 回答:1
sculcb
不打开的话出现The executable D:\program files\abaqus6.10\6.10-1\exec\standard.exe aborted with system error code 693. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
2013年6月9日
