请教前辈高人,大哥大姐,我的模型怎么了~哪里出错分析不下去~~
浏览:170289 回答:6
我做的是个锅,上下两层,中间是个硅胶,连接两个部分,
我想分析在锅装满东西的情况下,装满总重3kg
提起把手,中间的硅胶会不会断裂,
可是,数据和载荷都做好了,就是分析不下去,
不知道原因在哪里,
刚学这个软件,模型是solidworks做的.
哪位大神帮帮我,我记你们一辈子的好!!!!!!快交作业了,折磨我好几天多谢前辈高人!
inp加上了,是不是数据的问题,不懂了,我要疯了
Error in job silicone5: The volume of 2 elements is zero, small, or negative. Check coordinates or node numbering, or modify the mesh seed. In the case of a tetrahedron this error may indicate that all nodes are located very nearly in a plane. The elements have been identified in element set ErrElemVolSmallNegZero.
Job silicone5: Analysis Input File Processor aborted due to errors.
Error in job silicone5: Analysis Input File Processor exited with an error.
Job silicone5 aborted due to errors.
提起把手,中间的硅胶会不会断裂,
不知道原因在哪里,
请问,你是在哪里找到硅胶的材料参数的?
