Optisruct773报错,想问一下怎么处理呀?
浏览:3168 回答:1
*** ERROR # 773 ***
 When a grid has no rotational stiffness, then this rotational d.o.f.
  cannot be an independent d.o.f in an RBE3.
                RBE3 id =  2164178
                grid id =  1413426
    weighted components =   123456
  You should remove the rotational d.o.f. in the RBE3 for this
  independent GRID.
 There were 368 error messages during input processing.
  The first message is repeated below:
  *** ERROR # 773 ***
                 RBE3 id =  2164178
                 grid id =  1413426
   independent GRID.
 *** Run terminated because of error(s) in the input data.
请问这个怎么处理?
Wonderful仿真
连接有问题,得检查下,目前贴出来的只是冰山一角
2025年11月13日
